Bel Canto dac selges.
Ny pris er 60.300,-
Selges for14.000,-
Kjøpt i 2019 og fremstår som meget pent brukt.
Les test her: Bel Canto Design DAC3.7 (stereotimes.com)
Bel Canto DAC 3.7 Specifications:
Digital Section:
Maximum Data Input Rate:
24bit Data at 192KS/s: AES XLR, SPDIF BNC/RCA, ST Fiber, TOSLINK
Master Clock Jitter: 70 femtoseconds RMS, 100Hz-1MHz
Analog 24/192 DAC Section:
Maximum Output: 5.5 Vrms balanced XLR, 2.5 Vrms RCA
Output Impedance: 200 ohms balanced XLR, 100 ohms RCA
Frequency Response: 20 Hz-20 KHz, +/- 0.25dB
THD+N: <0.0015%, 5.5Vrms balanced out, 1KHz
Output Noise: 3uVrms A-weighted 20Hz-20KHz
Dynamic Range: 126dB A-weighted 20Hz-20KHz
Analog 24/192 ADC Section:
Maximum Input: 2.5 Vrms RCA
Input Impedance: 12K ohms RCA
THD+N: 0.003%, 2.5Vrms in, 1KHz
Dynamic Range: 110dB, A-weighted 20Hz-20KHz
General:
Power Usage On: 8W
Power Usage Off: 0.0W
Power Requirement: 12VDC
Dimensions: 8.5" W x 12.5" D x 3.5" H (216 mm x 318 mm x 88 mm)
Weight: 14lbs. (6.5 kg)
VBS1 Specifications:
Maximum Output: 12VDC at 0.8A
Output Voltage: 12VDC +/- 5%
Output Voltage Noise: <27 Microvolts RMS, un-weighted 0 Hz-100 KHz
General:
Power Usage On: 10W typical
Weight: 13lbs. (6.5 kg)
Ny pris er 60.300,-
Selges for14.000,-
Digital Section:
General:
Power Usage On: 8W
General:
- Originalemballasje
- Ja
