Vi selger en Ayon S-3 rør-DAC/nettverksspiller/pre-amp som er tatt i innbytte fra en kunde. Et par nye likeretterrør (6Z4) følger i tillegg med, ser jeg. Utgangsrørene er 6H30 (NOS).
Ønsket pris: NOK 24 000,-
Frakt: Kan hentes på vår adresse eller sendes med Posten (gratis)
Produsenten skriver:
Ayon S-3 – Vacuum Tube Streamer – Tube Network Player – Volume Control
Affordable Excellent – Remarkable Performance!
The S-3 is a ground-breaking design. This ultimate combination of a new modern design and time proven concepts, will deliver music and superb sound performance that you would expect from an Ayon product–with maximum home audio flexibility. The S-3 includes a network player, analog preamplifier and a world class D/A-converter that gives the highest obtainable performance.
Produktside
Omtale
Spesifikasjoner:
Produktside
Omtale
Spesifikasjoner:
Network-Player | Ayon S-3 |
Conversion rate | 192kHz / 24 bit |
Tube complement | 6H30 |
Dynamic range | > 118dB |
Channel separation | >105dB 20 Hz to 20 kHz |
Output level @1 kHz / 0,775V -0dB /RCA | 2V fixed or 0 – 2V rms variable |
Output impedance Single-Ended-RCA | ~ 700 Ω |
Digital ouput | 75 Ω S/PDIF (RCA) |
Digital inputs | 75 Ω S/PDIF (RCA & up to 24/192kHz), TosLink (up to 24/192kHz) 110 Ω AES/EBU (up to 24/192kHz) 75 Ω BNC (up to 24/192kHz) I2S (up to 24/192kHz) Front mounted USB type ‘A’ socket for USB “pen”/hard disk drive Rear mounted USB type ‘A’ socket for USB “pen”/hard disk drive |
Network inputs | RP-SMA plug Wifi Aerial input (“wireless” network connection) 802.11b/g UTP RJ45 10/100Mbps socket (“wired” network connection) |
S/N ratio | > 110 dB |
Frequency response | 10Hz – 50kHz +/- 0.3dB |
Total harmonic distortion @ 1kHz | < 0.002% |
Remote control | Yes |
Analog – Line Inputs & output | 2 pair RCA and 1 pair RCA out |
Analog – Main outputs | 1 pair / RCA & 1 pair / XLR |
Dimension (Wide x Deep – incl. terminals x High – incl. feet) cm | 48 x 39 x 12 cm |
Weight, unit only | 12 kg |
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
