Figaro M i Xiralic black.
Audio Solutions gir virkelig mye for pengene og blir ofte sammenlignet med mye dyrere merker. Med Figaro M får du en høyttaler som musikalitet og engasjement. Dynamikken. åpenheten og bassfundamentet gir deg timesvis med musikk uten og gi lyttertretthet.
HiFi Class "Recommendation" award
Best of High-End 2018 award
Best Buy 2018 award
AVShowrooms "Best Sound" 2018 award
Best product of 2018 award
Best product of 2019 award
RED Fingerprint 2019 award
Exceptional Value 2019 award
Figaro! maintains timeless AudioSolutions' design accents and gracefully slides into the overall product portfolio. Designed to look solid, and be the accent of the living room or disappear in it with the help of 17 different unique finishes. Make your Figaro! look the way you want. Make the speaker stand out by choosing one of two front baffles a.k.a "Stealth Grille". All floor-standing models are 3-way systems. Unique midrange in Figaro speakers works in extended band in order to reduce crossover distortions in a most critical area for the human ear (1000-1500Hz).
Spesifikasjoner:
Dimensions (HxWxD) : 1120mm x 272mm x 470mm; 44.1 x 10.7 x 18.5in
Weight : 41 kg/90 lbs each
Shipping weight : 45 kg/99 lbs each
Sensitivity : 91.5 dB @ 2.83V 1m
Nominal power handling : 140 W rms
Maximum unclipped power handling : 280 W;
Impedance : nominal 4,0 ohms
Crossover frequency : 400 Hz; 4000 Hz
Frequency response (in-room environment) : 32-25000 Hz
Drivers : 2,5cm silk dome tweeter, 15.2cm ER paper cone mid, two 18.3cm ER paper cone bass drivers
Best Buy 2018 award
Spesifikasjoner:
Tilstand | Ny |
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
