Selger en strøken Audio Note DAC 2.1 Level B Signature.
Dacen er i strøken tilstand. Den ble kjøpt ferdig bygget hos www.upgradeaudio.no og kostet kr 20.000 ny. Den er ikke blitt modifisert etter dette! Det er nettopp satt inn nytt RCA NOS 6x5 likeretter rør. Har to coax-innganger.
Passer ypperlig til Klipsch, JBL, Avantgarde Acoustic!
Konklusjonen i anmeldelse av Audio Note DAC 2.1 fra www.enjoythemusic.com:
"I was simply amazed at how refined this DAC sounded. So many try to overdue the music by bringing too much detail to the forefront. In turn, they can become aggressive sounding. The 2.1x Signature DAC retained all of the detail without being overbearing or fatiguing in the least. It was a welcomed change over the sound of the typical DAC's that have passed in front of me over the past few years.
When it comes to 'refinement' and audio gear, I've learned one thing over the years; you get exactly what you paid for. That's not to say that lesser expensive gear sounds bad. It's just that better engineered gear using better quality parts (generally) sounds better. I've found this to be true time and time again. This holds true with the Audio Note 2.1x Signature DAC. Where the Audio Note takes you, is well worth the price of admission.
Here at the end of my time with the Audio Note 2.1x Signature DAC, I'll have to admit that I'm definitely going to miss this piece when it's shipped back. I've not heard a better DAC in my system. Though it still isn't vinyl, it's quite few steps closer. For those of you in the market for a true high end tubed DAC, I can wholeheartedly recommend the Audio Note 2.1x Signature. Keep in mind if your audio budget is a bit larger, Audio Note offers six models above the 2.1 that (I can only imagine) get better as the price goes up."
For dem som har behov for usb-inngang, kan en Musical Fidelity V-Link USB-S/PDIF converter brukes mellom PC og dacen: http://www.musicalfidelity.com/products/vSeries/v-linkii/. Dette vil være en langt bedre løsning i forhold til jitter og galvanisk skille, enn å bruke usb-inngangen på en usb-dac! For mer info, les beskrivelse av denne løsningen i Stereophile: http://www.stereophile.com/content/musical-fidelity-v-link-usb-spdif-converter-0
PM, SMS eller ring for mer info!
