Kan sees og høres i butikken vår i Stavanger, Lagårdsveien 77
Ordinærpris: 52.900,-
The ATOHM GT Series range capitalizes on our renowned experience and expertise in designing prestigious drivers and high-performance loudspeakers. They sum up our engagement to continuously and exclusively develop unique products where ultimate performance, ease of integration and elegant design come together. ATOHM “ABSOLUTE SERIES” drivers, themselves the result of many years of research and a vast number of tests, serve as the heart of the GT SERIES model range. Every driver component, every loudspeaker and Atohm’s exclusive technologies have all been specially designed in-house within our own research & development department. They comprise an indivisible whole with the single goal of transcending emotions and providing the listener with total sound immersion. From the simple yet refined lines, to the breathtaking audio performances, every effort has been made to offer an unrivalled pleasure of the senses.
Exceptional drivers… Conceived using Finite Elements method and laser interferometric measuring systems, Atohm drivers feature high-end materials, exclusive technologies, oversized magnet motors, and have been optimized to minimize all forms of non-linearity. Atohm drivers are characterized by extended frequency response, long excursion, high power handling and very low distortion, and each unit is designed and built to the highest standards in the Industry.
Outstanding performances… Exceptional drivers, perfectly optimized loads, “gentle slope” crossovers with time compensation, controlled directivity, very high power handling, extensive quality control processes and precise tweeter pairing: ATOHM’s expertise and cutting edge technologies are combined to deliver extraordinary musical performances.
3 steps to acoustic precision… “Depending on your room, your choice of electronic components, and your own personal taste, a switch at the back of the speakers allows you to choose the frequency response and the definition level in the Mid-High frequencies.”
SPECIFICATIONS
SPECIFICATIONS
Floorstanding speaker : | 2 +1 ways bass reflex |
Power handling : | 200 Wrms |
Peak power : | 400 W |
Impedance : | 6 ohms |
Efficiency : | 90 dB/2.83V/1M |
Frequency response : | 40 Hz - 30 kHz |
Frequency roll off : | 2.5 kHz |
Midbass unit : | LD150CR08 (*2) |
Tweeter : | SD28ND04RD |
Filtering slope : | 1rst order with tweeter delay |
Cabinet : | 22mm MDF with multilayers curved sides |
Finish : | Piano gloss lacquer Black / White / Rosewood / Wengnut / RAL as option |
Dimensions : | 1085*200*265 (mm) 42.7*8*10.5 (inch) |
Weight : | 26 kg / 58 lbs |
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
