Allnic'en har vært lite brukt da denne har stått koblet opp mot den av platespillerene som jeg har brukt aller minst.
Nyprisen var midt på 30k-tallet når jeg bestilte/kjøpte min i årsskiftet 2018/2019.
Listening
So how does Allnic H-1201 phono preamp make my system sound? Like every Allnic product I have heard, it creates space and transparency. I had the H-1201 and the H-3000 in the house at the same time and the H-1201 gives you a big part of the soundstage and transparency of its big brother. The H-1201 is as detailed as any preamp I have heard without spending at least twice the money. Like it’s big brother, it never sounds overly edgy nor does it spotlight every little thing.
You get very good musical flow that allows the music listening experience to be relaxing with absolutely no listening fatigue. At the same time it’s not overly smooth or warm sounding. I found the music very exciting and emotionally enveloping with the H-1201 in my system. It doesn’t have quite the breath and immediacy of the H-3000 or my Shindo Giscours, but it’s very good in these areas.
Scale, dynamics, power
In these three areas the H-1201 is not as quite as good as its big brother or my Giscours, but it has a big, dynamic, powerful sound that defies its price tag. The H-1201 allows instruments to have a life-like size without seeming bloated.
SPECS
Listening
SPECS
- INPUTS:
- One (1) pair Moving Coil (MC) unbalanced (RCA)
- One (1) pair Moving Magnet (MM) unbalanced (RCA)
- Ground: Two (2) x screw type terminal
- OUTPUT: One (1) pair x unbalanced (RCA)Frequency (RIAA): 20Hz ~ 20KHz (±0.3db)Voltage Gain: MM: +38db (1KHz)MC: Variable: +22dB, +26dB, +28dB, +32dB (1Khz)Input Impedance: MC up to 280Ω, MM 47kΩMaximum Input Voltage:
- (MM, non-clipping): 20Hz / 30mV
- 100Hz / 60mV
- 1KHz / 300mV
- 10KHz / 500mV
- THD (Total Harmonic Distortion): Less than 0.3% (1KHz, Output 1V)Output Impedance: 1.2KΩ (on-off method)S/N Ratio: -68db (CCIR, 1KHz)Power Consumption: 20W / 220V @ 60HzTUBES:
- E180CC - New old stock - approximately electrically (not sonically) equivalent: CV8431, 7062, 5965, 12AV7, 6414, 6829
- Fuse: AC 2A, 250VDimensions: 310mm (~12.3 inches) x 230mm (~9.1 inches) x 140mm (~5.6 inches) (W x D x H)
- Originalemballasje
- Ja
- Orig. kvittering
- Nei
- Forsendelse
- Avtales nærmere
