Audio Agenten
Butikk Aerial Acoustics 7CC
Senterkanal
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Sør-Trøndelag
Pris
Kr 20.000
Annonse beskrivelse
Annonse nummer: 230707
På lager i Nero metallic. Ord pris 45,000kr.
Frequency Response 55 Hz – 25 kHz +/- 2 dB
Sensitivity 87 dB at 2.83 Vrms and 1.0 meter on axis
Impedance 4 ohms nominal, 3 ohms minimum, low reactance
Power Requirements 25 to 300 watts (8 ohm rating) recommended
Woofers 2 x 6.7? long-stroke design with aluminum cones, large voice coils, large magnets and cast frames
Midrange 5? cast frame design with strong acceleration-factor dual magnets and special Papyrus cone
Tweeter 1? woven soft ring dome with dual magnets, non-resonant chamber, machined aluminum face plate
Crossover 600 Hz and 3.5 kHz. Premium components, polypropylene capacitors, silver solder, Teflon wiring
Controls 2 x 3-position rotary switches for fine midrange and tweeter adjustment and boundary compensation
Cabinet Inert construction with stressed multi-layer curved walls, extensive bracing and wool insulation
Baffle 0.5? thick inert aluminum baffle for midrange and tweeter mounting
Grille Curved grille with magnetic mounting
Finish Architectural veneers. 4 layer priming and 10 layer hard hand-polished high gloss finish
Connectors 4 binding posts with jumpers for single-wire, bi-wire or bi-amp use
Hardware 4 adjustable spikes with black spike covers to protect furniture
Dimensions 23.6 x 8.0 x 11.9? deep including grille (600 x 204 x 302)
Weight 39 pounds each. 46 pounds packed
Besøk gjerne www.audioagenten.com
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Avtales nærmere
Audio Agenten
Torget karakterer
Vurderinger
Andre annonser av Audio Agenten
