Audio Agenten
Butikk Aerial Acoustics 5T
Stativhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Sør-Trøndelag
Pris
Kr 28.000
Annonse beskrivelse
Annonse nummer: 230706
På lager for demo.
Orginale staiver 5,800kr
Frequency Response 48 Hz – 25 kHz +/- 2 dB
Sensitivity 87 dB at 2.83 Vrms and 1.0 meter on axis
Impedance 4 ohms nominal, 3 ohms minimum, low reactance
Power Requirements 25 to 200 watts (8 ohm rating) recommended
Woofer 6.7? long-stroke design with Papyrus blend cone, large voice coil, dual magnets and cast frame
Tweeter 1? woven soft ring dome with dual magnets, non-resonant chamber, machined aluminum face plate
Crossover 2.7 kHz. Premium components, polypropylene capacitors, silver solder, Teflon wiring
Cabinet Inert construction with stressed multi-layer curved walls, extensive bracing and wool damping
Port Front facing with smooth laminar flow for extended bass response on shelves or stands within 2? of walls
Finish Architectural veneers with 4 priming layers and 10-layer hand-polished hard high gloss finish
Nero metallic black multi-layer automotive paint.
Connectors 4 binding posts with jumpers for single-wire, bi-wire or bi-amp use.
Hardware 4 adjustable spikes with black spike covers to protect furniture
Dimensions 15.0 x 7.9 x 12.6? deep including grille (380 x 200 x 323)
Weight 23 pounds each, 56 pounds per pair packed
Besøk gjerne www.audioagenten.com
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Avtales nærmere
Audio Agenten
Torget karakterer
Vurderinger
Andre annonser av Audio Agenten
