Selger Accostic Arts power
Integrert forsterker kjøpt desember 2021.
Solid bygget og yter 170 watt med fantastisk gjengivelse.
Dagens ny pris er 108.900,-
Kan lyttes på i Lørenskog med PMC Fact 12 signatur. En kombinasjon som flere utropte til beste lyd på Hortenmessa i 2021.
POWER I highlights
POWER I highlights
- Audiophile integrated stereo power amplifier with high output
performance - 12 selected Bipolar output transistors of highest quality
- Encapsulated 500 VA toroidal core transformer of premium quality for high output reserves; separate windings for preamp section and for power amp section
- Integrated, switchable headphones amplifier of premium quality
- Very good smoothing thanks to more than 80,000 µF power supply capacity
- High damping factor for high output reserves
- Integrated protective circuit switches ascents off when clipping, HF oscillations, too high temperature or too high DC offset occurs
- Constant low operating temperature due to generously dimensioned heat sink
- 2 x balanced high level inputs (XLR)
- 3 x unbalanced high level inputs (RCA/Chinch), can be configured as high-level input or “SURROUND-BYPASS”
- 1 x unbalanced pre-output (RCA/Chinch), configurable as RECORD output or preamp output
- Separate level adjustment for each input
- Premium quality, gold-plated speaker terminals
- Premium quality, long-term stable relays
- Highly accurate microprocessor controlled volume control
- Encapsulated high grade volume potentiometer Full metal housing for optimum shielding
- Front panel made of brushed aluminum; turning knobs/push buttons made of massive and chromed brass
- ACCUSTIC ARTS® remote control RC II
- ACCUSTIC ARTS® POWER I is “Handmade in Germany”
- Specifications
Inputs:
1 x unbal. as high level input or SURROUND-BYPASS (RCA)
Headphones output:
1 x metal female jack 6.3 mm; <25 Ω
Output:
1 x unbalanced pre-output (RCA); 47 Ω
Signal difference left/right:
< 0.4 dB (from 0 dB to -40 dB)
Input resistance:
balanced: 2 x 50 kΩ
unbalanced: 50 kΩ
Total transformer power:
max. 500 VA (watts)
Power supply capacity:
more than 80,000 µF
Rated power output (at THD+N = 0.1 %):
2 x 260 watts on 4 Ω
2 x 170 watts on 8 Ω
Rise time / fall time:
4.6 µs with 4 Ω load
Signal-to-noise-ratio:
-97 dBA (ref. 6.325 V) – A weighted
Distortion (THD+N):
> 0.015
Damping factor:
> 700
Power Consumption:
approx. 60 watts (without load)
Dimensions (H x W x D):
145 x 482 x 430 mm / 5.7 x 19 x 17 inches
Weight:
approx. 22 kg / 48 lbs.
- Originalemballasje
- Ja
- Forsendelse
- Kan sendes
