Gjallarhorn Audio
Butikk 2,5m Atlas Mavros Transpose 2-2 høyttalerkabler (innbyttevare)
Høyttalerkabler
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Akershus
Pris
Kr 9.000
Annonse beskrivelse
Annonse nummer: 252671
Vi selger 1 par 2,5m Atlas Mavros Transpose 2-2 høyttalerkabler med spade-spade terminering som er tatt i innbytte fra en av våre kunder. Annonsebildet viser faktisk vare.
Listepris: NOK 30 000,- (dette er nå en utgått modell)
Bruktpris: NOK 9 000,-
Informasjon fra produsenten:
Mavros uses very high purity OCC (Ohno Continuous Casting) copper conductors. The OCC process is named after professor Atsumi Ohno, who in the late 1970s, discovered that by heating the drawing mould to a higher temperature than the molten copper you intend to cast, then cooling it soon after, the result is one long, high purity (99.9997%) metal crystal.
These high-purity monocrystal conductors are used in a multi-stranded layout, wrapped in individual low-loss microporous PTFE (Teflon™) insulators, and twisted to help lower electromagnetic interference. The four separate conductors are then wrapped in cotton, an additional layer paper, then wraps the assembly in PVC and shrouds it in an outer black cotton sleeve.
This obsessive attention to detail – and the combination of materials & assembly methods which was only finalised after exhaustive testing – produces a cable which HiFi World’s reviewer described as‘ the best he’d ever heard’ and HiFi Plus summarised as ‘one of the very, very best. ’
Our goal to make cables which have no discernable character or sound of their own, which would in itself be a form of distortion – Mavros is engineered to ‘disappear’ in your system, leaving the performance of your equipment to speak for itself. It should be noted though that Mavros requires a ‘burn-in’ period during which the sound will continue to improve.
Originalemballasje
Nei
Orig. kvittering
Ja
Forsendelse
Kan sendes
Gjallarhorn Audio
Torget karakterer
Vurderinger (100)
Andre annonser av Gjallarhorn Audio
