High end strømkabel selges da jeg har en til overs av de.
http://www.oyaide.com/ENGLISH/AUDIO/products_category/power_plugs_iec_connectors/pg472.html
Plugs
?EU 2 Pin mains plug to IEC plug
?Conductor material: Copper
?Plating process: Gold plating (1.5 micron)
Cable
?Conductor: OFC wire
?Fully shielded: Dielectric insulator, copper braid and aluminum foil
?Cable O.D.: 16mm (diameter)
?Wire diameter (gauge): 2.3mm (11 AWG)
?Vol/Amp: 100V~250V 15A
?Cable length: 1.5m
?Cable weight: 620g (include plugs)
150 i frakt med sporing.
Kan bytte i sorte små pene og gode høyttalere.
Plugs
Cable
?Cable length: 1.5m
