Gold Note - DS-10 på lager nå
DAC, Streamer, Forforsterker ( kun digitale innganger ), Hodetelefonforsterker
For mer informasjon: https://butikk.pmaudio.no/produkt/el...re-dac/ds-10-2
Epost: kontakt@pmaudio.no
Tlf.: +47 38 18 31 15
Mob.: +47 917 13 655
Navn:      DS-10.jpg
Visninger: 399
Størrelse: 274.2 Kb Navn:      back-3.jpg
Visninger: 394
Størrelse: 327.8 Kb
“The DS-10 presents mature, audiophile sound, but what is most surprising, at the level we
can expect from expensive, specialized CD players! There is also the icing on the cake for people who like streaming music via Bluetooth. The DS-10 showed off a perfectly balanced and
rich sound of a quality not differing from what we can get in combination with a classic CD
HIFI CLASS
TECHNICAL SPECIFICATIONS
D/A Converter AKM AK4493 PCM up to 32bit/768kHz and DSD512 native
Network Connectivity: LAN/WLAN (WiFi): 802.11b/g via RJ45 10/100Mbps socket
Streaming in High Quality: AIRPLAY, ROON Ready, TIDAL & MQA via Tidal, QOBUZ, SPOTIFY &
Spotify Connect, DEEZER, V-Tuner
Smartphone App: available for iOS and Android
Digital Inputs:
Ethernet LAN and Wi-Fi DSD64 (DoP) Resolution: PCM up to 24bit/192kHz;
Bluetooth 5.0;
RCA S/PDIF coaxial PCM asynchronous up to 24bit/192kHz;
2x TOS-optical PCM asynchronous up to 24bit/192kHz;
COAX asynchronous up to 24bit/192kHz;
AES/EBU balanced PCM asynchronous up to 24bit/192kHz;
USB-A port to feed USB flash memories, FAT32/NTFS formatted playing DSD64 and PCM up to
24bit/192kHz;
USB-B asynchronous up to DSD512 and PCM up to 32bit/384kHz
3 Audio Outputs: 1 RCA; 1 XLR; 1 headphone 6,3mm Jack on the front panel
Display & SKC: clear and easy to read display and single knob to control every function
