Nyhet! Audiovector R-Serie
"MEANT TO TRANSCEND EXISTING SOUND BARRIERS, THE NEW AUDIOVECTOR R SERIES BORROWS A LOT OF TECHNOLOGY FROM ITS BIGGER SIBLINGS, R 11 ARRETÉ AND R 8 ARRETÉ. TRUE HIGH-END SPEAKERS DO NOT COME MORE COMPACT THAN THE AUDIOVECTOR R SERIES."
Audiovector R-Serie
A NEW LOOK WITH MUCH BETTER PERFORMANCE
A timeless classic has now been updated after 3 years of developing
• The R series reflects our “form follows function” concept
• The R series cabinet and baffles are minimum 25% stronger
• The R rear baffle is deeper, stronger and more solid for lower coloration
• The R 3 series plinth has more than minimum 30% improved airflow and a bigger footprint
• The R series front baffles use of a new lamination technique with improved resonance control
NEW TECHNOLOGIES PROMISE A NEW WORLD OF DETAILS & DYNAMICS
Over dimensioned technology. Relaxed and detailed sound
• The R 3 Arreté AMT tweeter is our fourth generation AMT. Now with integrated S-Stop filter
• The R 3 tweeter is over dimensioned to the n-th degree. It reaches 53.000 Hz.
• New Evotech accelerated soft dome and damping material for the Signature models
• New Carbon fiber sandwich membranes promises increased detailing and improved soundstage
• New chassis for improved mechanical performances
• Second generation titanium voice coil technology for improved detailing
• Freedom Grounding® system brings a greater quality of musical reproduction and control
• 4th generation DFF low loss, low distortion filters for improved dynamics
HANDMADE HIGH-END PRECISION FROM COPENHAGEN, DENMARK
Designed, Manufactured, Controlled and Tested by educated artisans
• Handmade open back AMT
• New drivers are designed and made by Audiovector in Denmark
• Crossovers are designed and hand built in Denmark
• All speakers are hand built in Denmark by educated craftsmen
MORE ABOUT AUDIOVECTOR FREEDOM GROUNDING®
We knew we could extract more detail and better dynamics. We found out how
• Freedom Grounding® removes unwanted distortion between drive units
• Freedom Grounding® connects to either artificial or true earth
• Freedom Grounding® brings spatial information forward
• Freedom Grounding® brings out hidden details unheard before
Oslo Hi-Fi Center
Oslo Hi-Fi Center sine annonser
Jérôme ANDRÉ - Avantagrde Acoustic Mini Konsert / Hi-Fi Show!!!
  • 1
Nå til til helgen skjer det! Selveste Jérôme Andrè - Fra Avantgarde Acoustic kommer og holder en liten mini konsert på Avantgarde-horn, med lærerike foredrag. Vi garanterer gåsehud, og en...
Opplev Focal Scala Utopia EVO under Vårpuls 15. til 17. mars på @oslohificenter !!! 🎶🇫🇷🔥
Nå er det ikke lenge igjen til VårPuls 2024
  • 22
Nå er det ikke lenge igjen til VårPuls 2024 Vårt eget Hi-Fi Show her på Vika! Showet er åpent og gratis for alle! Nyheter, Norgespremierer, Internasjonale utstillere, og ikke minst fantastisk lyd...
Endelig er messen her!
  • 3
Vi gleder oss til å se dere alle! Det blir en rekke gode tilbud på nytt og brukt som er verdt å få med seg, ta turen innom eller sjekk ut vår nettbutikk ila helgen for å gjøre en rekke gode kjøp...
Endelig Høstpuls måneden!
Endelig Høstpuls måneden! Velkommen til Oslo Hi-Fi Center den 13-15. Oktober! I tradisjon tro kommer det en rekke representanter fra både norske og utenlandske leverandører som viser frem og...
Vi ønsker alle hifi-interesserte hjertelig velkommen innom, nå på lørdag! Kl 12- 16.
Dyktige Isak Strand fra Multirom, kommer innom hos oss og viser frem den nye Naim New Classic 300 Serien. Bestående av: NAIM NAC 332 Preamp NAIM NS 333 Steamer / dac NAIM NAP 350 Monoblokker NAIM...
