I løpet av oktober vil vi presentere de ulike modellene i Paradigm sin Persona serie. Som mange har fått med seg er Paradigm Persona en av de mest roste høyttalerserier de siste årene i høyere prisklasse.
Siden vi er litt sent ute, så kommer 9H i denne omgang, og 7F om kort tid.
Persona 9H - En av de beste
Persona 9H er i en rekke omtaler omtalt som en av markedets aller beste høyttalere uansett pris. Ofte blir 9H satt opp mot konkurrenter som koster opp mot 1mill. Ikke bare blir den anmeldt likeverdig, den blir også foretrukket. 9H er en rå høyttaler med oppløsning, fundament, autoritet og kontroll. De aktive bassene sørger for godt fraspark, og romkorreksjonen kan redusere problemer i bassområdet.
Les hva pressen sier:
"...the Paradigm Persona 9H is a superb speaker system for the money and also provides dedicated room-frequency compensation in a more purist form. Both products show that room compensation is now available in far better sounding forms, can deal effectively with room interactions and speaker locations, and significantly improve key aspects of the realism of the listening experience in any system. The promise of digital processing has been around for years. Legacy and Paradigm show that this promise is now really being kept."
—Anthony Cordesman, The Absolute Sound
"Good things do come in rela- tively small packages, although this is a nearly 300-pound speaker that is 51" high. It uses four new ultra-high ex- cursion woofers, two 700-watt amps, and ARC-2 digital room compensation to produce incredibly deep, accurate bass at to 19Hz and going as low as 15Hz. It also features an advanced beryllium tweeter and midrange driver, and provides equally outstanding midrange and treble perfor- mance in every aspect. Detail, dynamics, depth, and imaging are all excellent. Sensitivity is 96dB, allowing use with even low-power triodes and pro- viding an exceptional sense of life with more powerful amps."
—The Absolute Sound
"Paradigm has created one of the world’s finest loudspeakers the right way, by applying what they’ve learned from decades of research, design and manufacturing know how to produce a speaker with no compromises. There’s nothing they don’t do, nothing they won’t play and from what I can deduce, nothing they won’t partner with regarding electronics."
—Jeff Dorgay, TONEAudio
"Sometimes, music can feel like magic. Hearing a familiar song can send chills up your spine, change your entire mood, or even take you to the same place you first heard it. Of course, music is only as good as the tools used to play it. Enter the Paradigm Persona 9H. Acoustically, the Persona 9H can out-muscle heavyweights twice its price. The 1-inch tweeter, 7-inch mid/bass driver, and four 8.5-inch woofers are calibrated with Anthem Room Correction, powered by separate DSP-controlled 700W amps, and wrapped in a housing that oozes audiophile distinction."
—Patrick McCarthy, Sr. Content Editor, Dealerscope
"Paradigm Persona 9H Loudspeaker is a state of the art speaker designed by one of Canada's leading audio companies. It may be expensive but it's one of the best speaker systems in its class. It delivers superb upper-octave and midrange response, and it can deliver flat, detailed, and room-corrected bass that normally requires a massive separate subwoofer.".
—David Richards, Smarthouse [Australia]
Kampanje
Vi kommer i løpet av oktober til å kjøre kampanje på hver modell vi presenterer. Kampanjen varer frem til neste modell presenteres.
Kampanjen på Persona 9H varer frem til og med onsdag 31.10.18
NB! 6 måneders prisgaranti. Vi garanterer at produktet vil ikke komme på kampanje til samme eller lavere pris innenfor en periode på minimum 6 mnd.
Kampanjen vil også være tilgjengelig gjennom din foretrukne forhandler.
Persona 9H Standard utførelse: 269.990,- (349.990,-)
