Bricasti har i år lansert M21 Classic DAC, M21 Platinum DAC og M12 Platinum DAC/Preamp.
Jeg har hatt M1, M12 og M15 i lang tid, og dette er ekstremt vellydende produkter som man ikke har det store behovet for å bytte ut hvis man ser på bruktmarkedet.
Model 21 Digital to Analog Converter
The M21 Platinum Series is the trifecta of digital to analog conversion. Three independent and user-selectable digital to analog signal paths are available: delta sigma and ladder dac for PCM conversion and for DSD playback, true direct DSD. All digital input types are supported, with direct output or hard-wire bypass of the analog attenuator.
The M21 Digital to analog converter is the continued evolution of both the M1 Special Edition and the M12 Dual Mono Source Controller.
Model 12 Dual Mono Source Controller
The new M12 is a modern front end to any system. All digital inputs types are supported as well as balanced and unbalanced analog inputs, all with precise analog gain control, seamlessly integrated into one product, your source controller.
The M12 builds upon the proven design of the M1 SE D/A converter so your digital sources are handled and converted in the best way. To that we add to it a pure dual mono analog signal path with high resolution analog gain and level control, controlling the output stage of the D/A converter in the analog domain with no loss of resolution and pass thru analog inputs for your analog sources. Like the M1, the M12 is a dual mono design with 3 power supplies and separate left and right analog power supplies and digital and analog processing.
Tom Egil
tom@endpoint-audio.com
47832922
Tom Egil
47832922
