Nye ProAc Response K3 kan nå forhåndsbestilles
ProAc lanserer siste tilskudd i Response K serien, modellen K3, nå i sommer. K3 vil være i demonstrasjon hos oss ifra høsten av.
Anbefalt utsalgspris (veiledende pris) for standard finish havner på NOK 117 000,- før rabatt. Premium finish vil koste NOK 140 400,- før rabatt.
Response K3 er nå tilgjengelig for forhåndsbestilling i vår nettbutikk: Gjallarhorn Audio - Nettbutikk
Her er informasjon fra ProAc om K3:
The K series range of speakers are called so because of the use of Kevlar in the construction of the drive units. So far we have only used Kevlar and Carbon Fibre for bass and lower midrange reproduction in large enclosures. These cones have a light, stiff quality, the Kevlar has more warmth making excellent bass transients and extension. Cone material is something that ProAc have been developing over the last fifteen years with an emphasis on Carbon fibre and Kevlar. A new Kevlar cone was developed which would work into the midrange far better than previous Carbon fibre or Kevlar cones, this also has the added benefit of a phase plug giving better detail and dispersion.
The new Kevlar drive unit was developed for the K3 and has excellent weight to the bass as well as good extension with a detailed and uncoloured midrange. This new Kevlar unit would go into a new speaker called the K3, two of these units are used with our ribbon tweeter placed centrally in our K constructed cabinet. A high quality crossover was specially designed for the K3 to seamlessly mate with the ribbon tweeter and this new crossover uses high quality components split for bi-amping and bi-wiring and connected directly to the terminals.
As far as sound quality goes the K3 has a wonderfully electrostatic type of midrange very clear and detailed, with a dynamic bass response.
We are sure the K3 will give customers who desire music from full orchestral to loud rock the desired results with ease.
Og her er spesifikasjonene:
skorob
Brumunddal
Må snart få tatt turen ned! :). Veldig spennende butikk du har nå!
Gjallarhorn Audio
Gjallarhorn Audio sine annonser
Besøk oss på Oslo HiFi Show nå i helgen
Vi har intet mindre enn 6 Norgeslanseringer under Oslo HiFi Show nå i helgen. Du finner oss på rom 106 og 108 i første etasje. Under kan du se hvilke produkter det er Norgespremiere på. Velkommen...
Gjallarhorn lanserer franske B.audio i Norge
  • 5
B.audio er et forholdsvis nystartet firma, men de har i løpet av kort tid blitt anerkjent for sitt gode design og høye lydkvalitet. Firmaet ble grunnlagt i 2016 av brødrene Cédric og Sébastien...
Sveitsiske Stenheim endelig i Norge
  • 10
Varemerket Stenheim ble etablert i 2010 av fem elektronikkingeniører som tidligere hadde jobbet i det sveitsiske high-end firmaet Goldmund. Deres første høyttaler, Alumine, ble lansert i 2011...
Gjallarhorn showroom holder stengt i romjulen
  • 6
Vi lar julefreden senke seg og holder vårt showroom stengt i romjulen. Men vår nettbutikk vil være betjent og det vil fremdeles være mulig å hente varer på vår adresse ved kjøp eller hjemlån i...
Juletilbud på Harbeth (-25%)
Det blir juletilbud på Harbeth ut desember for å få ned vår lagerbeholdning. Alt av modeller, bortsett fra toppmodellen, er på lager i de fleste finisher. Merk at tilbudet om 25% rabatt på...
Juletilbud på SPEC (-25%)
Vi kjører juletilbud på SPEC i hele desember ved å tilby 25% rabatt på alle produktene som befinner seg på lager. SPEC sine integrerte forsterkere er unike klasse D forsterkere med lav effekt...
