Lumin Lanserer AMP effektforsterker og X1 Streamer
  • Dette er de to nyhetene Lumin kom med på Munchen messa i år.
    Her er en presentasjon av de begge:
    LUMIN X1 makes improvements in every possible location:
    New processor delivers native DSD512 & PCM768 playback
    Dual Mono design throughout maximises channel separation
    Dual ES9038Pro SABRE DACs featuring 140dB dynamic range
    Femto Clock System with precision FPGA distribution
    New Output Buffer design
    Dual Mono dual stage linear regulator
    Optical Network provides complete isolation from network digital noise
    USB Digital Audio Output supports Native DSD512
    Entirely new Power Supply
    New solid billet CNC casing design
    Separate digital & analogue circuitry
    Low-noise linear regulator
    New 9-pin output connector
    Available as an upgrade for existing S1 / A1 / T1 customers
    X1 Specification
    DSD Support:
    Up to DSD512 22.6MHz, 1-bit
    PCM Support:
    Up to 768kHz, 16–32-bit, Stereo
    Analog Output Stage:
    Dual ESS SABRE32 ES9038Pro DAC chips
    Fully balanced layout with high-quality components
    Output connectors coupled with dual LUNDAHL LL7401 output transformers
    Upsampling rates & bit depths:
    DSD128 upsampling option for all files
    PCM 384kHz upsampling option for all files
    Digital Output Stage:
    USB:
    Native DSD512 support
    PCM 44.1–768kHz, 16–32-bit, Stereo
    BNC SPDIF:
    PCM 44.1kHz–192kHz, 16–24-bit
    DSD (DoP, DSD over PCM) 2.8MHz, 1-bit
    Optical Network:
    Industry-standard SFP
    1000Base-T Gigabit Ethernet
    Adapter may be needed for your particular switch/cables
    Use simultaneously with RJ45 (e.g. connect one to router and one to LUMIN L1 or NAS)
    Power Supply:
    External solid billet cnc dual-toroidal
    9-pin Output Connector
    Physical:
    Finish:
    Black anodised brushed aluminium
    Lumin (solid aluminium chassis):
    350mm (W), 345mm (D), 60mm (H), 8kg
    PSU (solid aluminium chassis):
    106mm (W), 334mm (D), 60mm (H), 4kg
    Lumin AMP
    Matched styling. Unmatched performance.
    160W per channel into 8Ω
    320w per channel into 4Ω
    2-channel design can be configured in Stereo, Dual Mono or Bridged mode
    Class AB Amplification
    Discrete Circuit
    No global feedback
    DC, overload and overheating protection
    Bespoke 650VA transformer
    LUMIN Amp Specification
    Audio Inputs:
    Analogue input: 1 x XLR pair, 1 x RCA pair
    Input impedance: 200kΩ
    Speaker Outputs:
    320W per channel into 4Ω
    Output impedance: 0.1Ω
    Signal to noise ratio: 105dB unweighted
    Power Mains Supply
    Available in 220–240V AC and 110–120V AC versions ~ 50/60Hz
    Volume control:
    Volume is controlled by the LUMIN app
    Construction:
    CNC-machined from a single billet for front, top and sides. Thick 8mm walls, rear panel and base plate
    Finish:
    Black anodized brushed aluminium or Raw brushed aluminium
    Physical:
    Finish:
    350mm (W), 374mm (D), 104mm (H), 19kg
    Prisen er 129.990,- pr stk.
    Sjekk ut Lumins nye hjemmeside: LUMIN - The Audiophile Network Music Player Family
    Tom Egil
    tom@endpoint.audio
    47832922
    Erdal Stereo
    Spennende produkter og med den erfaringen jeg har med A1, er det all grunn til å tro at man får mye godlyd for pengene.
Endpoint Audio
Endpoint Audio sine annonser
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
Lumin D3
Lumin D3
Lumin D3 ble lansert tidligere i år og er en vesentlig oppgraderring i forhold til den tidligere modellen D2. Vi gir 15% på Lumin D3 nå før jul - 25.400,- Testene begynner å komme og...
