Resultater 1 til 12 av 12
Abonnér på denne artikkelen
  1. Gradient lanserer ny modell: 1.4
    11 Kommentarer Av pmaudio - 24.04.2018 18:16
    Så lanseres Gradient`s siste kreasjon som heter 1.4
    1.4 er en fortsettelse og videreutvikling av de tidlige modellene, 1-serien
    Som før - kontrollert spredning
    1.4 er nå første modell med det spesialkonstruerte coax-elemetet, designet i et samarbeid mellom Gradient og SEAS, kun for Gradient
    Kontakt for info:
    e-post: kontakt@pmaudio.no
    Telefon: 38 18 31 15
    https://pmaudio.no/nyheter/gradient-142018/4/24
    Gradient beskriver tingene best selv:::
    GRADIENT 1.4
    It was just 35 years ago when we decided to take our own way and not to follow anyone else. Not to fallow industry conventions and evident solutions. With one single goal: to design a loudspeaker that sounds excellent in all kinds of rooms.
    During the centenary of Finland's independence Gradient added another chapter to the legendary Gradient 1.-line.
    The sprit of the Gradient 1. - speakers combined with the inventions we have made during these years make the 1.4 a real unique loudspeaker, destined to become an instant classic.
    THE LATEST COAXIAL DRIVER WITH NO COMPROMISES
    The first coaxial structure in our speaker elements was carried out in Revolution model, launched in 1993. Thereafter, several versions of the coaxial speaker elements developed together with Seas have been used in our loudspeakers.
    The new Gradient 1.4 is the first speaker utilizing our latest coaxial technology made exclusively for Gradient in Norway. A 176mm pre-coated reed paper cone cone handles frequencies up to 2500Hz. High frequencies from 2500Hz to over 20kHz are reproduced by a 25mm Al/Mg-dome tweeter placed at the apex of the midrange cone. Such a point source is generally accepted as an ideal sound source for its excellent phase and amplitude response. The end result is an extremely accurate, stable and three dimensional soundstage.
    SPHERICAL ACOUSTIC RESISTANCE ENCLOSURE
    To minimize reflections from the speaker cabinet, the coaxial element is mounted in a spherical enclosure. The sphere is an ideal form with no structural interfaces and discontinuities.
    Still Gradient is not Gradient without something completely new and unique. From the very beginning it was clear that the new Gradient 1.4 will utilize our acoustic resistance enclosure - technology, like used in many previous Gradient models. Now this is made as ideal as possible: Symmetric spherical housing leaks “anti sound” from the opening behind the sphere, cancelling back radiation and early reflections from the surfaces behind the loudspeaker.
    The backward radiation of the Gradient 1.4 is attenuated by 20dB at mid frequencies which is only one percentage of the total sound energy.
    In a nutshell: the room influence to the sound remains very small giving the Gradient 1.4 a very similar sound characteristic in many different rooms.
    BASS DOWN TO 30HZ
    Low frequencies below 200 Hz are reproduced by a bassreflex enclosure tuned at 27Hz. Large crossection area of the reflex tunnel guarantees no breathing noise even at high sound levels.
    220mm long throw woofer made by Seas in Norway is facing towards the floor. The woofer has an extremely stiff aluminium cone giving tremendous bass precision.
    FUNCTIONAL DESIGN
    Every aspect of the speaker form has a meaning. Acoustic design and function determine the shape. There is nothing more to add - there is nothing left to take away.
    The cabinet of the speaker is made of advanced technopolymer in Finland. Together with the ideal form of the speaker exceptional combination of stiffness and rigidness is obtained to eliminate cabinet vibrations.
    The finishing of the speaker cabinet, available in graphite black and white, is durable providing easy to clean and long-lasting surface. For years to come.
    Navn:      gradient-14.jpg
Visninger: 821
Størrelse: 75.0 Kb Navn:      gradient-14 (4).jpg
Visninger: 799
Størrelse: 96.4 Kb Navn:      gradient-14 (3).jpg
Visninger: 808
Størrelse: 93.3 Kb Navn:      gradient-14 (2).jpg
Visninger: 809
Størrelse: 68.3 Kb
  2. Antall kommentarer 11
    Hifi Freak Distinctive's Avatar
    Dec 2006
    Tagget i
    7 Innlegg
    Album
    Veldig sober design!
  4. #3
    Bransjemedlem
    Jun 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra Distinctive Se Innlegg
    Gradient`s høyttalere er stort sett av litt spesiell design - men som Gradient sier:: Every aspect of the speaker form has a meaning. Acoustic design and function determine the shape.
    Altså - funksjonen som Gradient alltid er ute etter - bestemmer formen på deres høyttalere.
    Og funksjonen Gradient alltid er ute etter er å minimere rommets og høyttalernes egen påvirkning av lyden - sånn at høyttalerne lyder mest mulig likt i alle slags rom.
    De lager ikke spesielle design for designet sin skyld.
    Ett av målene ( virkemåten ) med formen på disse høyttalerne er å unngå all refleksjon fra en flat frontbaffel og fargingen av lyden derifra.
    I tillegg er det noe med dette designet ( som ikke jeg kan forklare hvordan skjer pr nå ) som kansellerer bakoverutstråling ( akkurat som på andre Gradient høyttalere ) - og dermed unngå refleksjoner fra bakvegg - om man plasserer høyttalerne nær bakvegg.
    Toppmodulen ( kula ) kan vris / vinkles uavhengig av bassmodulen under.
    De første 1.4 kommer til lager og demo denne uka så det skal bli spennende å høre resultatet, om den kan konkurrere med REVOLUTION og HELSINKI 1.5
  5. #4
    Overivrig entusiast vrøvl's Avatar
    May 2009
    Tagget i
    0 Innlegg
    Dødskul! Er den dyr?
  6. #5
    Hifi Freak Holmium's Avatar
    Feb 2002
    Tagget i
    0 Innlegg
  7. #6
    Bransjemedlem
    Jun 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra vrøvl Se Innlegg
    Den kommer på kr 56900,00
    Leveres i sort eller hvit
    Vi kommer antagelig til å legge ut et introduksjonstilbud i løpet av noen dager så er det interessant så følg med på hjemmesiden vår - inne på TILBUD siden
    Paul Mortensen
  8. #7
    May 2005
    Tagget i
    0 Innlegg
    Når kan vi forvente en Revolution med det nye coaxelementet? Eller er 1.4 modellen å anse som den nye toppmodellen?
  9. #8
    Bransjemedlem
    Jun 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra busserulle Se Innlegg
    Nye REVOLUTION er snart klar!!!
    Vi ( PM Audio ) er med i prosessen vedr valg av terminaler så når dette er bestemt så har vi REVOLUTION på plass i Kristiansand og forhåpentligvis mange andre steder i landet.
    Hvilken modell som blir toppmodellen tør ikke jeg å spå om på dette tidspunktet i og med at jeg ikke har lyttet på 1.4 enda
    Fraktselskapet melder at de skal leveres til oss i dag så da kommer forhåpentligvis 1.4 i spill denne helgen.
    Paul Mortensen
  10. #9
    Medlem cykelmyg's Avatar
    Nov 2017
    Silkeborg, Danmark
    Tagget i
    0 Innlegg
    Findes der tegninger eller fotos af den indvendige opbygning af bas kabinettet?
    Cykelmyg.
  11. #10
    May 2005
    Tagget i
    0 Innlegg
    Sitat Sitat fra pmaudio Se Innlegg
    Paul Mortensen
    Kunne jeg selv valgt terminaler på mitt neste sett med Revolution, ville det garantert falt på disse. Utrolig brukervennlige og skikkelig laget. Litt kostbare kanskje, men en høyttaler som Revolution burde vel ikke ha noe dårligere.
    https://www.madisoundspeakerstore.co...ing-post-pair/
  12. #11
    Bransjemedlem
    Jun 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra cykelmyg Se Innlegg
    Cykelmyg.
    Det finnes nok på fabrikken men vi har ikke noe
  13. #12
    Bransjemedlem
    Jun 2007
    Tagget i
    0 Innlegg
    Paul Mortensen
    Såfremt de passer så skal vi nok ordne dette. Hvilke terminaler er det du tenker på??
    Paul
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
