Kalibreringspakke for platespilleroppsett.
Kun via Endpoint Audio og godkjente forhandlere.
Acoustical Systems leverer allerede markedets mest nøyaktige protraktor for å sette opp din platespiller perfekt. Sammen med Analogmagik og Acoustical Systems har du nå muligheten til å fintune hele oppsettet og få analoglyden så perfekt som det lar seg gjøre.
Analogmagik leverer en pakke med programvare og testplater som lar deg måle alle parametre i prosessen.
vi har 3 kalibreringspakker hvor vi har satt sammen Analogmagik + Acoustical Systems sine løsninger!
Pakke 1:
Acoustical Systems Smartractor (4995,-) + Smartstylus (1195,-) + USB Lydkort anbefalt av Analogmagik (1300,-) + Analogmagik All In One Cartridge Setup Software & Test LPs. 7500,-
Totalpris for alle deler 14.990,-
Pakkepris 13.000,-
Pakke 2:
Acoustical Systems Smartractor (4995,-) + Analogmagik All In One Cartridge Setup Software & Test LPs. 7500,-
Totalpris for alle deler 12.495,-
Pakkepris 11.200,-
Pakke 3:
Totalpris 8.800,-
Pakkepris 8000,-
What is AnalogMagik ?
AnalogMagik is a Windows based turntable cartridge calibration software designed by Richard H. Mak and a team of engineers. It offers a scientific and repeatable method of calibrating every cartridge setup parameter, including:
Turntable Speed
Azimuth
Vertical Tracking Angle / Stylus Raking Angle
Anti-Skating
Optimizing Phono Stage Loading
Optimizing Phono Stage Gain Setting
Vertical Tracking Force
Measuring Vibrations
Determining Resonance Frequencies
AES Wow & Flutter
After you have performed a basic alignment on your turntable's cartridge using an appropriate alignment tractor, our software and Test LPs will help you optimize and fine-tune all the above setup parameters to achieve a more accurate analog cartridge setup.
Simply follow the onscreen instructions, and the program will guide you through all the test functions. It will also tell you what "optimal" numbers to look for, and what cartridge adjustments you need to make to get there.
https://youtu.be/O1CBS5CfRtI
Sjekk ut https://www.analogmagik.com/ og alle tutorials på siden for å få et bilde av hva dette er.
Her ser vi tydelig hvor nøyaktig Acoustical Systems protraktor er!
Tom Egil
vidarje
Rasta
Dette burde være standardutstyr for alle med skikkelige platespillere. Er det stor forskjell i lyden hvis spilleren er satt opp med dette versus en vanlig god protractor og bruk av øret? Artige og lærerike videoer på hjemmesiden til AnalogMagik.
motoren
Flekkefjord
Sikkert gode greier og det kunne jo være greit å ha men synes det var en stiv pris? :)
Hver sin lyst
Peringolf
Fersking
Har klart meg med en Rega protractor i mange år.+øyne, ører og en nøyaktig "linjal"
Endpoint Audio
Tønsberg
Endpoint Audio
Endpoint Audio sine annonser
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
