Den som venter på noe godt...
Endelig har vi fått inn et solid parti med Chords etterlengtede streamer "Poly", et must for alle Mojo-eiere.
"Poly is our revolutionary streaming module for Mojo and is based on a condensed high-level PC, with data server, DLNA receiver, Wi-Fi hub, Bluetooth module and SD card reader/player functionality, plus highly sophisticated software. Poly enables wireless audio playback from smartphones and for the first time, negates the need for a cable between the two devices.
Poly acts as a Wi-Fi and Bluetooth hub and can access music in a number of ways including streaming over Wi-Fi, network storage devices (NAS) and collections stored on SD cards (using MPD). Bluetooth connectivity and AirPlay functionality provide real flexibility with smartphones and enable multiple Mojo/Poly combinations to be used throughout the home, providing a high-quality multi-room streaming playback solution.
Poly removes the original need for a wired link between the smartphone and Mojo, and is controlled wirelessly from Android and iOS apps on your phone. When connected to Mojo, Poly conveniently slips into pockets, bags and handbags — it doesn’t need to be hand-carried or regularly checked like other players."
For mer informasjon se HER
