Resultater 1 til 1 av 1
Abonnér på denne artikkelen
  1. Blue Horizon Professional Rack System
    0 Kommentarer Av Oslo Hi-Fi Center - 23.06.2017 18:00
    Blue Horizons etterlengtede rack system er endelig leveringsklart!
    "Key Features:
    – Unique triple layer mixed grain direction bamboo breaks up shelf standing waves; solid machined stainless steel acts as shock spot for draining resonance without adding sonic signature
    – Solid stainless steel parts give you the flexibility in height spacing to accommodate all sizes of audio electronics. Three shelf rod lengths available
    – The sophisticated design allows you to create a unique rack that fits your style and space·
    – Sanctum isolation platforms fit neatly under all audio components, protect the rack finish as well as improving component perfourmance
    – Elegant cable management system keeps loose wire under control and allows signal and power cable to be kept separated
    – Easy to assemble, adjust and tighten, no special tool required
    – Available in single and double shelf; Single: 550x450x3mm, double 600x450x30mm (WxDxH)"
    Disse kan selvsagt besiktiges i våre lokaler i Dronning Mauds Gate 1-3 og ønsker du en demo, ta kontakt på:
    info@oslohificenter.no
    eller
    22 01 04 30
    Navn:      blue-horizon-rack-system.jpg
Visninger: 353
Størrelse: 41.5 Kb
    For mer informasjon se:
    BLUE HORIZON PROFESSIONAL RACK SYSTEM
    Vedlagte bilder
  2. Antall kommentarer 0
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
