Nyheter fra Bricasti
Bricasti utvider porteføljen sin og kommer nå med en Nettverksavspiller - Bricasti M5
Deres Bricasti M12, kommer med tilsvarende innebygget og vi spiller via Jriver til denne. I løpet av Mai er det klart for integrering med ROON.
Det er fantastisk gode produkter i alle ledd - og vi har M12, M15 og snart M5 inne for demonstrasjon og utlån. Vi har solgt og hørt disse komponentene i oppsett som er svært forskjellig oppbygget, og Bricasti blir som regel stående på grunn av sin nøytrale ærlighet.
The M5, Network Player PRIS - 22.500,-
The Bricasti M5 network player is a network interface and media renderer. With wide support for DNLA and other popular network protocols, the M5 delivers pristine lossless audio from your network to your Digital to analog converter; your music server can go anywhere you choose. Connects to your LAN via Ethernet and Wi-Fi, with SPDIF, AES and USB outputs supporting sample rates up to 192k PCM and DSD 64.
Play from anywhere
The M5 plays ethernet wired or wirelessly over your data network. In addition, audio listeners have become accustomed to having a computer server and additional storage drives directly in the listening environment. This can get messy with the added cables and power supplies that accompany them. With the M5 Network Player you can find new freedom from your server devices and place them anywhere on your network, away from your system.
Purity of sound
The M5 is a dedicated DNLA and Roon Ready audio media renderer. Simple, raw data is served to the M5 over the network from your NAS or server and only then does data become rendered as a real-time audio stream to its SPDIF, AES or USB outputs, connecting to your D/A like our M1SE to do its magic. Many computer servers play dual roles as archival systems and players but not when you have a dedicated player like the M5. With the M5 dedicated player the audio rendering is in the M5, and close to its D/A destination for a pure, noise free experience that we believe is exceptional.
A class unto itself
The M5 is built solid. The chassis is milled from solid aluminum with beautifully rounded corners all the way around. Inside the chassis lies the Bricasti media player and powered by the same linear power supply as found in the M1 digital to analog converter for superb low noise performance under the most demanding circumstances. The M5 takes the Network player experience to the next level, and no add-ons are needed with the M5, it comes complete.
tom@endpoint-audio.com
47832922
BigSwifty
Men f... Tom - ska´n værra nødt til å L E S E innleggene nå, da !!! :)
svart-hvitt
Jeg er nysgjerrig på hva slags programvare Bricasti legger opp til for å strømme musikk, ikke minst trådløst. Det hevdes 24/192-kapasitet over wifi? Finnes en brukerveiledning e.l.?
Endpoint Audio
Tønsberg
Det finnes ikke noe mer info enn det som ligger på hjemmesidene til Bricasti.
Enheten ble lagt ut på deres hjemmeside igår, men regner med at det kommer noe mer etterhvert.
Polka
24/192 over wifi klarer min tilårskomne Squeezebox også, så det bør vel ikke være så spesielt.
svart-hvitt
Jepp, men ikke for Mac...
Tror Mac alltid vil være begrensningen hvis man ikke lager en annen wifi-protokoll enn Airplay - og det vet jeg ikke om er så enkelt inne i Mac-arkitekturen...
Så jeg er alltid nysgjerrig på nye produkter og om de har løst Mac-problemet.
A
ANM
Det er vel temmelig lett å løse dette Mac-problemet selv SH?
Minutten
Denne støtter vil ikke Airplay engang, så hvor skulle mac være noe begrensning? Streamer det meste fra mac med Roon, Lumin app og Linn Kazoo, ingen problemer.
svart-hvitt
Ja, jeg kan bruke Windows.
Kjenner du til en trådløs protokoll som fungerer for Mac og som støtter mer enn 16/44?
Hele poenget er jo at musikkstrømmen skal gå trådløst fra Mac til break-out-boks.
Kanutus
Nesodden
Denne skal jo strømme fra en NAS, ikke direkte fra en PC/Mac ... Eventuelt kan du sikkert koble opp en USB-disk til den. At det finnes kontroll-apper på denne som også fungerer med Mac er jeg 100% sikker på ...
Endpoint Audio
Tønsberg
Jeg bruker en App som heter 8Player som kontroll, og da strømmer den direkte fra NAS, og til andre kompatible enheter som sonos, lumin osv. Funker knall! Og også DSD filer.
srtorp
Takk for tips ang 8player, lastet ned gratis versj. så nå kan jeg spille fra L1 til Sonos osv. Vet du om det er forskjell opp til betal versj.
Petterone
Rogaland
Hvis du kjører roon på pc/mac trenger du vel ikke en streamer ? Men kjører ut rett på dac ?
Minutten
Du kan bruke en pc/mac som "End point" med Roon, de fleste streamere er jo små pcer.
Endpoint Audio
Endpoint Audio sine annonser
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
Lumin D3
Lumin D3
Lumin D3 ble lansert tidligere i år og er en vesentlig oppgraderring i forhold til den tidligere modellen D2. Vi gir 15% på Lumin D3 nå før jul - 25.400,- Testene begynner å komme og...
