Da har storebroren til den allerede bejublede Nova 150 ankommet butikken, en herlig kombinasjon av kraft og finesse, må oppleves!
Nøkkelfunksjoner:
"The nova300 is an exceptional beast.
Its combination of ALL of the above (read: real world flexibility) and serious output power, both into loudspeakers and headphones, comes wrapped in shell amply suited to luxury department store shelf space where its über high-end audio aspirations could end up obscured."
"..the nova300 is the homecoming king, the captain of the team, and the president of the senior class, rolled up into one item. Power, control, and finesse. This is the nova you want." Computer Audiophile
For mer informasjon se:
PEACHTREE NOVA 300 - Oslo Hi-Fi Center
Nøkkelfunksjoner:
- ESS Reference 9018K2M Sabre DAC
- 32-Bit/384kHz PCM and 5.6MHz DSD (double-DSD) compatibility
- New generation ICEPower amplification - 300 watts per channel @ 8Ω
450 watts per channel @ 4Ω - Extensive internal grounding
- Designed by a world-class engineering team
- Asynchronous USB, Coax and (2) Optical inputs
- Asynchronous iOS input for direct digital input from Apple Lightning devices - with exclusive Peachtree DyNEC (Dynamic-Noise Elimination Circuit) technology (pending certification)
- Phono (MM) input
- Home Theater Bypass
- Loop feature to add an external tube buffer, EQ or other processor into the signal path
- Pre-Out for use as preamp/DAC or with subwoofer
- HIGH OUTPUT discrete headphone amplifier
- Optional Wi-Fi module to be announced
- Available in Gloss Ebony Mocha and Piano Black
- Made in North America
Digital Audio Review
24.3 KB Visninger: 1.154
40.8 KB Visninger: 1.112
44.5 KB Visninger: 1.197
