Peachtree Nova 300 er nå på lager og i demo!
Da har storebroren til den allerede bejublede Nova 150 ankommet butikken, en herlig kombinasjon av kraft og finesse, må oppleves!
Nøkkelfunksjoner:
  • ESS Reference 9018K2M Sabre DAC
  • 32-Bit/384kHz PCM and 5.6MHz DSD (double-DSD) compatibility
  • New generation ICEPower amplification - 300 watts per channel @ 8Ω
    450 watts per channel @ 4Ω
  • Extensive internal grounding
  • Designed by a world-class engineering team
  • Asynchronous USB, Coax and (2) Optical inputs
  • Asynchronous iOS input for direct digital input from Apple Lightning devices - with exclusive Peachtree DyNEC (Dynamic-Noise Elimination Circuit) technology (pending certification)
  • Phono (MM) input
  • Home Theater Bypass
  • Loop feature to add an external tube buffer, EQ or other processor into the signal path
  • Pre-Out for use as preamp/DAC or with subwoofer
  • HIGH OUTPUT discrete headphone amplifier
  • Optional Wi-Fi module to be announced
  • Available in Gloss Ebony Mocha and Piano Black
  • Made in North America
"The nova300 is an exceptional beast.
Its combination of ALL of the above (read: real world flexibility) and serious output power, both into loudspeakers and headphones, comes wrapped in shell amply suited to luxury department store shelf space where its über high-end audio aspirations could end up obscured."
Digital Audio Review​
"..the nova300 is the homecoming king, the captain of the team, and the president of the senior class, rolled up into one item. Power, control, and finesse. This is the nova you want." Computer Audiophile
For mer informasjon se:
PEACHTREE NOVA 300 - Oslo Hi-Fi Center
Oslo Hi-Fi Center
Oslo Hi-Fi Center sine annonser
Opplev Focal Scala Utopia EVO under Vårpuls 15. til 17. mars på @oslohificenter !!! 🎶🇫🇷🔥
Nå er det ikke lenge igjen til VårPuls 2024
  • 22
Nå er det ikke lenge igjen til VårPuls 2024 Vårt eget Hi-Fi Show her på Vika! Showet er åpent og gratis for alle! Nyheter, Norgespremierer, Internasjonale utstillere, og ikke minst fantastisk lyd...
Endelig er messen her!
  • 3
Vi gleder oss til å se dere alle! Det blir en rekke gode tilbud på nytt og brukt som er verdt å få med seg, ta turen innom eller sjekk ut vår nettbutikk ila helgen for å gjøre en rekke gode kjøp...
Endelig Høstpuls måneden!
Endelig Høstpuls måneden! Velkommen til Oslo Hi-Fi Center den 13-15. Oktober! I tradisjon tro kommer det en rekke representanter fra både norske og utenlandske leverandører som viser frem og...
Vi ønsker alle hifi-interesserte hjertelig velkommen innom, nå på lørdag! Kl 12- 16.
Dyktige Isak Strand fra Multirom, kommer innom hos oss og viser frem den nye Naim New Classic 300 Serien. Bestående av: NAIM NAC 332 Preamp NAIM NS 333 Steamer / dac NAIM NAP 350 Monoblokker NAIM...
Endelig HøstPuls Igjen! VI ønsker alle velkommen!
Vi har gleden av å invitere til hi-fi messe hos oss i Dronning Mauds Gate! Årets Høstpuls går av stabelen 13-15. Oktober Les mer om eventet her: (https://oslohificenter.no/hostpuls-2023)...
