Resultater 1 til 6 av 6
Abonnér på denne artikkelen
  1. Avantgarde Acoustic Zero XD Teil Aktiv er nå leveringsklar
    5 Kommentarer Av Oslo Hi-Fi Center - 16.01.2017 15:10
    "The ZERO - TEIL AKTIV is the logical consequence of the ZERO product line.
    It combines the body structure of the ZERO with the 25 years Avantgarde knowhow in semi active speaker design. Basically it is scaled down version of the UNO in the sifgnifiantly smaller enclosure of the ZERO. The objective was to accomplish the clarity and power of its “bigger“ brother in a significantly reduced enclosure.
    The 400mm spherical midrange horn covers a wide bandwidth down to 300 hz. The active subwoofer supplements the balance between spherical horn performance and low frequency reproduction. It is actuated by one 12 inch long–excursion driver powered by a 500 Watt amplifier.
    All horn drivers are equipped with 8 ohm voice coils with 104 dB system sensitivity. This is 32 x times the dynamic range of a conventional 87 dB box speaker.
    Using Avantgarde Acoustic´s™ CDC–technology, we precisely align the frequency response, sensitivity of the driver, the geometry of the membrane and the air chamber at the horn throat to the response curve of the spherical midrange horn. This way the midrange driver has no passive filter components in the signal path – routing the music signal directly to the voice coil of the driver engine. Less components, less interactions, less friction ensuring more detail.
    Frequency control in the low frequencies is managed by an advanced digital sound processor. The digitally controlled frequency crossover ensure a seamless integration of the bass response to the spherical horns. The DSP is equipped with 10 parametric equalizers to fine control the sound to the customers taste and to the acoustics of the room."
    For mer informasjon se:
    AVANTGARDE ACOUSTIC ZERO TEIL AKTIV - Oslo Hifi Center
    Vedlagte bilder
    Siste redigert av Oslo Hi-Fi Center; 16.01.2017 kl. 17:14.
  2. Antall kommentarer 5
    Hifi-interessert
    Jun 2016
    Tagget i
    0 Innlegg
    Forskjell TEIL AKTIV kontra "vanlig" XD: Uten Dac og mid/trebleamp ??
  4. #3
    Bransjemedlem Oslo Hi-Fi Center's Avatar
    Jun 2013
    Tagget i
    0 Innlegg
    Se min butikk
    Klikk her
    "Basically it is scaled down version of the UNO in the sifgnifiantly smaller enclosure of the ZERO. The objective was to accomplish the clarity and power of its “bigger“ brother in a significantly reduced enclosure."
  5. #4
    Hifi-interessert
    Jun 2016
    Tagget i
    0 Innlegg
    teil
    Sitat Sitat fra Oslo Hi-Fi Center Se Innlegg
    Ja.. akkurat..
  6. #5
    Overivrig entusiast GjeEsp's Avatar
    Sep 2006
    Arendal
    Tagget i
    0 Innlegg
    Virker som den er semi aktiv, ergo ikke hel aktiv slik som Pro1 og XD. Innebygget forsterker (noe kraftigere enn i XD), til subwoofer og ellers tilkobling for separat forsterker til drift av diskant/mellomtone.
    Om dette gir bedre lyd aner jeg ikke, men for mitt vedkommende tar det bort det momentet jeg fant attraktivt ved disse høyttalerene, nemlig det at kun kilde behøver tilkobles.
    Ønsker man å prøve forskjellige forsterkeres lydsignatur for å "fintune" egne preferanser åpner det jo helt klart for endel muligheter.
    Selv er jeg forøvrig strålende fornøyd med mine Zero Pro1 til den bruken jeg har for dem og nyter fraværet av alskens ting samt ledningestjafs
    Gjert
  7. #6
    Hifi Freak Olav2's Avatar
    Apr 2014
    Tagget i
    1 Innlegg
    Den eneste mulige forklaringen på at det skulle være en vesentlig annen lydsignatur i disse, må være hvis de benytter seg av andre og bedre drivere enn Zero. Jeg vet ikke om de gjør det?
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
