Avantgarde Acoustic Zero XD Teil Aktiv er nå leveringsklar
"The ZERO - TEIL AKTIV is the logical consequence of the ZERO product line.
It combines the body structure of the ZERO with the 25 years Avantgarde knowhow in semi active speaker design. Basically it is scaled down version of the UNO in the sifgnifiantly smaller enclosure of the ZERO. The objective was to accomplish the clarity and power of its “bigger“ brother in a significantly reduced enclosure.
The 400mm spherical midrange horn covers a wide bandwidth down to 300 hz. The active subwoofer supplements the balance between spherical horn performance and low frequency reproduction. It is actuated by one 12 inch long–excursion driver powered by a 500 Watt amplifier.
All horn drivers are equipped with 8 ohm voice coils with 104 dB system sensitivity. This is 32 x times the dynamic range of a conventional 87 dB box speaker.
Using Avantgarde Acoustic´s™ CDC–technology, we precisely align the frequency response, sensitivity of the driver, the geometry of the membrane and the air chamber at the horn throat to the response curve of the spherical midrange horn. This way the midrange driver has no passive filter components in the signal path – routing the music signal directly to the voice coil of the driver engine. Less components, less interactions, less friction ensuring more detail.
Frequency control in the low frequencies is managed by an advanced digital sound processor. The digitally controlled frequency crossover ensure a seamless integration of the bass response to the spherical horns. The DSP is equipped with 10 parametric equalizers to fine control the sound to the customers taste and to the acoustics of the room."
For mer informasjon se:
AVANTGARDE ACOUSTIC ZERO TEIL AKTIV - Oslo Hifi Center
Heipådeg
Forskjell TEIL AKTIV kontra "vanlig" XD: Uten Dac og mid/trebleamp ??
Oslo Hi-Fi Center
"Basically it is scaled down version of the UNO in the sifgnifiantly smaller enclosure of the ZERO. The objective was to accomplish the clarity and power of its “bigger“ brother in a significantly reduced enclosure."
Heipådeg
teil
Ja.. akkurat..???
GjeEsp
Arendal
Virker som den er semi aktiv, ergo ikke hel aktiv slik som Pro1 og XD. Innebygget forsterker (noe kraftigere enn i XD), til subwoofer og ellers tilkobling for separat forsterker til drift av diskant/mellomtone.
Om dette gir bedre lyd aner jeg ikke, men for mitt vedkommende tar det bort det momentet jeg fant attraktivt ved disse høyttalerene, nemlig det at kun kilde behøver tilkobles.
Ønsker man å prøve forskjellige forsterkeres lydsignatur for å "fintune" egne preferanser åpner det jo helt klart for endel muligheter.
Selv er jeg forøvrig strålende fornøyd med mine Zero Pro1 til den bruken jeg har for dem og nyter fraværet av alskens ting samt ledningestjafs :)
Gjert
Olav2
Den eneste mulige forklaringen på at det skulle være en vesentlig annen lydsignatur i disse, må være hvis de benytter seg av andre og bedre drivere enn Zero. Jeg vet ikke om de gjør det?
Oslo Hi-Fi Center
Oslo Hi-Fi Center sine annonser
Opplev Focal Scala Utopia EVO under Vårpuls 15. til 17. mars på @oslohificenter !!! 🎶🇫🇷🔥
Nå er det ikke lenge igjen til VårPuls 2024
  • 22
Nå er det ikke lenge igjen til VårPuls 2024 Vårt eget Hi-Fi Show her på Vika! Showet er åpent og gratis for alle! Nyheter, Norgespremierer, Internasjonale utstillere, og ikke minst fantastisk lyd...
Endelig er messen her!
  • 3
Vi gleder oss til å se dere alle! Det blir en rekke gode tilbud på nytt og brukt som er verdt å få med seg, ta turen innom eller sjekk ut vår nettbutikk ila helgen for å gjøre en rekke gode kjøp...
Endelig Høstpuls måneden!
Endelig Høstpuls måneden! Velkommen til Oslo Hi-Fi Center den 13-15. Oktober! I tradisjon tro kommer det en rekke representanter fra både norske og utenlandske leverandører som viser frem og...
Vi ønsker alle hifi-interesserte hjertelig velkommen innom, nå på lørdag! Kl 12- 16.
Dyktige Isak Strand fra Multirom, kommer innom hos oss og viser frem den nye Naim New Classic 300 Serien. Bestående av: NAIM NAC 332 Preamp NAIM NS 333 Steamer / dac NAIM NAP 350 Monoblokker NAIM...
Endelig HøstPuls Igjen! VI ønsker alle velkommen!
Vi har gleden av å invitere til hi-fi messe hos oss i Dronning Mauds Gate! Årets Høstpuls går av stabelen 13-15. Oktober Les mer om eventet her: (https://oslohificenter.no/hostpuls-2023)...
