Vi har nå Lumin på lager! Dette er plug and play med markedets beste app for styring og oversikt.
Vi har på lager
A1 - 69.990,-
T1 - 39.990,-
D1 - 19.990,-
M1 - 19.900,- (Nettverksspiller med forsterker) 2x60W
U1 - 64.990,- High end streamer uten DAC.
L1 - Server 2TB - 9.900,-
[h=2]Specification for all LUMIN Music Players[/h]
Tom Egil
47832922
tom@endpoint-audio.com
Vi har på lager
A1 - 69.990,-
T1 - 39.990,-
D1 - 19.990,-
- [h=3]Streaming Protocol:[/h]
- UPnP AV protocol with audio streaming extension
- Gapless Playback
- On-Device Playlist
- [h=3]Supported Audio File Formats:[/h]
- [h=4]DSD Lossless:[/h]
- DSF (DSD), DIFF (DSD), DoP (DSD)
- [h=4]PCM Lossless:[/h]
- FLAC, Apple Lossless (ALAC), WAV, AIFF
- [h=4]Compressed (lossy) Audio:[/h]
- MP3, AAC (in M4A container)
- [h=3]Supported Audio Sample Rates, Bit Depths, Number of Channels:[/h]
- PCM, 44.1kHz - 384kHz, 16 - 32bit, Stereo
- DSD, 2.8MHz, 1bit, Stereo (5.6MHz on LUMIN S1)
- [h=3]Upsampling rates & bit depths:[/h]
- DSD upsampling option for all files up to 96kHz
- [h=3]Supported Control Devices:[/h]
- All models of Apple iPad (v2 or later). iOS 5.0 or later required. Full Retina Display support.
- [h=3]App Features:[/h]
- High-resolution artwork. Artwork caching. AirPlay compatibility. Multiple-tag handling. ‘Composer’ tag support. Find & Filter. Tag browsing.
- [h=3]Input:[/h]
- Ethernet network 100Base-T
- USB storage, flash drive, USB hard disk (Single-partition FAT32, NTFS and EXT2/3 only)
- [h=3]Outputs:[/h]
- [h=4]Analog Audio:[/h]
- XLR balanced, 4Vrms, pin 2 Hot
- RCA unbalanced, 2Vrms
- [h=4]Digital Audio:[/h]
- [h=5]BNC SPDIF:[/h]
- PCM 44.1kHz–192kHz, 16–24bit
- DSD (DoP, DSD over PCM) 2.8MHz, 1bit
- [h=3]Finish:[/h]
- Raw brushed aluminium
- Black anodised aluminium finish is available as a special order item. Please contact your retailer for costs and lead time
- [h=3]Other:[/h]
- Firmware-upgradable for further features and enhancements
[h=6][/h]
Tom Egil
47832922
