Lumin Nettverksspillere på lager. Kan leveres innpakket i julepapir!
Vi har nå Lumin på lager! Dette er plug and play med markedets beste app for styring og oversikt.
Vi har på lager
A1 - 69.990,-
T1 - 39.990,-
D1 - 19.990,-
M1 - 19.900,- (Nettverksspiller med forsterker) 2x60W
U1 - 64.990,- High end streamer uten DAC.
L1 - Server 2TB - 9.900,-
[h=2]Specification for all LUMIN Music Players[/h]
  • [h=3]Streaming Protocol:[/h]
    • UPnP AV protocol with audio streaming extension
    • Gapless Playback
    • On-Device Playlist
  • [h=3]Supported Audio File Formats:[/h]
    • [h=4]DSD Lossless:[/h]
      • DSF (DSD), DIFF (DSD), DoP (DSD)
    • [h=4]PCM Lossless:[/h]
      • FLAC, Apple Lossless (ALAC), WAV, AIFF
    • [h=4]Compressed (lossy) Audio:[/h]
      • MP3, AAC (in M4A container)
  • [h=3]Supported Audio Sample Rates, Bit Depths, Number of Channels:[/h]
    • PCM, 44.1kHz - 384kHz, 16 - 32bit, Stereo
    • DSD, 2.8MHz, 1bit, Stereo (5.6MHz on LUMIN S1)
  • [h=3]Upsampling rates & bit depths:[/h]
    • DSD upsampling option for all files up to 96kHz
  • [h=3]Supported Control Devices:[/h]
    • All models of Apple iPad (v2 or later). iOS 5.0 or later required. Full Retina Display support.
  • [h=3]App Features:[/h]
    • High-resolution artwork. Artwork caching. AirPlay compatibility. Multiple-tag handling. ‘Composer’ tag support. Find & Filter. Tag browsing.
  • [h=3]Input:[/h]
    • Ethernet network 100Base-T
    • USB storage, flash drive, USB hard disk (Single-partition FAT32, NTFS and EXT2/3 only)
  • [h=3]Outputs:[/h]
    • [h=4]Analog Audio:[/h]
      • XLR balanced, 4Vrms, pin 2 Hot
      • RCA unbalanced, 2Vrms
    • [h=4]Digital Audio:[/h]
      • [h=5]BNC SPDIF:[/h]
        • PCM 44.1kHz–192kHz, 16–24bit
        • DSD (DoP, DSD over PCM) 2.8MHz, 1bit
  • [h=3]Finish:[/h]
      • Raw brushed aluminium
      • Black anodised aluminium finish is available as a special order item. Please contact your retailer for costs and lead time
  • [h=3]Other:[/h]
    • Firmware-upgradable for further features and enhancements
    [h=6][/h]
Tom Egil
47832922
tom@endpoint-audio.com
Endpoint Audio
Endpoint Audio sine annonser
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
