Resultater 1 til 15 av 15
Nyhet: Reed Muse 3C
Abonnér på denne artikkelen
  1. Reed Muse 3C
    14 Kommentarer Av Endpoint Audio - 04.10.2016 13:15
    Vi har fått inn Reed Muse 3C platespilleren. En utrolig lekker platespiller med en interessant finesse som gir deg valget til å veksle mellom beltedrift eller mellomhjulsdrift. Man kan montere to armer for større fleksibilitet og det er innebygget sensor som indikerer at spilleren er i vater.
    Den er koblet opp i vårt demooppsett og vi vil også demonstrere spilleren hos Duet som er Reed forhandler i Oslo senere i høst.
    Navn:      IMG_8886.JPG
Visninger: 504
Størrelse: 67.5 Kb
    After more than three years idea-crunching and countless man hours of CADing, prototyping, programming and real-life testing, we built our first commercially available turntable - Reed Muse 3C. Is it somehow unique? Well, yes! Whether you are fan of friction-driven turntables (the famous Garrard is made that way), or if you think that the right way to build turntables is to use a pair of motors and a belt, Reed Muse 3C should catch your eye.Thanks to its unique and innovative design, you can convert friction-driven turntable to a belt-driven machine in 5 minutes.What is inside of our turntable?
    After extensive prototyping and long-term experiments we came up to a solution of using a reverse sliding thrust ball bearing for a main axis. Bearing ball is made either from steel or ceramics and the lateral stability is achieved by using very durable and low-noise polymer sliding bearing. Symmetrical drive system is designed to avoid radial bearing load, hence minimizing possible mechanical noise and ensuring longevity of a master bearing.Muse 3C is powered by two direct current motors and by design is friction-driven, however its major innovation is possibility to convert it to a belt-driven system in minutes by replacing traction rollers and putting on a belt (and, of course, setting a switch to a correct position). To prevent possible mechanical vibration, we use traction rollers (be it friction or belt) of different diameters, spinning at different velocities and having mathematically non-multiple diameters to driving disc diameter. Disc velocity is stabilized by quartz-based phase locked loop (PLL) system, so average speed deviation depends solely on the parameters of quartz crystal. Turntable drive is equipped with both mechanical and electronic protection systems.Turntable also features electronic inclinometer (electronic level dedicated to measure turntable slope/tilt angle), which allows user to achieve perfect horizontal alignment without using additional tools.Turntable can be equipped with one or two tonearms with effective length ranging from 9.5” to 12”.
    For info ta kontakt.
    tom@endpoint-audio.com
    47832922
    eller via våre facebook sider Endpoint Audio
  2. Antall kommentarer 14
    Hifi-entusiast vidarn's Avatar
    Mar 2002
    Tagget i
    2 Innlegg
    Hva blir prisen Tom?
  4. #3
    Bransjemedlem Endpoint Audio's Avatar
    Apr 2013
    Tønsberg
    Tagget i
    1 Innlegg
    Se min butikk
    Klikk her
    Torget
    Hei, Spilleren koster 158.000,-
  5. #4
    Bransjemedlem Audiomix's Avatar
    Jul 2004
    Tagget i
    7 Innlegg
    Album
    Torget
    26
    Ikke gjør som i videoen!
    Det er eller blir mer kritisk med finger fett på reimer og hjul enn på rør.
    Når en først skal demonstrere noe må det gjøres riktig.
  6. #5
    Apr 2013
    Tønsberg
    Tagget i
    1 Innlegg
    Se min butikk
    Klikk her
    Torget
    Det er sant - og det følger med hansker i pakken.
  7. #6
    Æresmedlem oct's Avatar
    Apr 2009
    Tagget i
    0 Innlegg
    Uansett, bør en slik spiller settes opp av forhandler.
    Overivrig entusiast svartkeiko's Avatar
    Feb 2013
    9395 KALDFARNES
    Tagget i
    0 Innlegg
    Album
    Nydelig spiller.De gutta der vet nok hva de holder på med.Og med Reed sine tonearmer bør nok denne være i toppsjiktet.Ja takk.
    Mvh Kenneth
  9. #8
    Apr 2013
    Tønsberg
    Tagget i
    1 Innlegg
    Se min butikk
    Klikk her
    Torget
    Den er utrolig enkel å sette opp, og rembytte til mellomhjul er så enkelt at det er laget for at brukeren gjør det selv. Tar ca 5 minutter.
  10. #9
    Apr 2009
    Tagget i
    0 Innlegg
    ^^ Ok. Flott spiller, er det iaff.
    Hifi Freak Vermin's Avatar
    Sep 2006
    Bjerkreim
    Tagget i
    1 Innlegg
    Den så helt fantastisk ut "live" i Horten
    https://youtube.com/watch?v=12et7HedQiI
  12. #11
    Hifi Freak Ingeniøren's Avatar
    Nov 2007
    Tranby
    Tagget i
    1 Innlegg
    Sitat Sitat fra Audiomix Se Innlegg
    Nå overdriver du vel litt....
  13. #12
    Æresmedlem motoren's Avatar
    Jan 2007
    Flekkefjord
    Tagget i
    25 Innlegg
    Det var faktisk en flott spiller som ikke ser ut som en olje rigg
    Æresmedlem LMC's Avatar
    Aug 2006
    Drøbak
    Tagget i
    7 Innlegg
    Torget
    1 av få "moderne" spillere som man får kjøpesug av........
  15. #14
    Æresmedlem bluesbreaker's Avatar
    Mar 2009
    Blåskogen
    Tagget i
    13 Innlegg
    Torget
    Nydelig spiller.
    Har hørt den i demo et par ganger.
    Et av de beste alternativene når en er villig til å legge penger i en platespiller.
  16. #15
    Hifi Freak Powerpoint's Avatar
    Apr 2003
    Tagget i
    7 Innlegg
    Utvilsomt en lekker platespiller
    Den vil stå seg godt sammen med topp notch drevet til CEC på husalteret.
    Skal vi se onkel Bernard i Brooklyn begynner å bli gammel, så var det tante Greta....mumle mumle...
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
