Resultater 1 til 4 av 4
Abonnér på denne artikkelen
  1. Game over. Mytek Brooklyn MQA ready DAC.
    3 Kommentarer Av Moiz Audio - 22.09.2016 13:31
    Navn:      Broolyn_dac_silver_front_side_view_IMG_48353.jpg
Visninger: 958
Størrelse: 39.2 Kb
    The Absolute sound har testet Mytek Brooklyn DAC. Klikk på bildet for å lese testen.
    Pris: 18500 Inkludert frakt.
    For eiere av Stere-192 DSD DAC tilbyr vi en inbyttedeal på 12000 NOK + frakt
    F
    or bestilling: ring 93047149, send mail til info@moiz.no eller PM
    Fra produsentens hjemmeside: mytekdigital.com
    Brooklyn is a reference USB2 DAC, line and phono analog preamplifier and a reference headphone amplifier.
    It integrates digital and vinyl hi-res playback for reference listening on headphones and speakers.
    SPECIFICATIONS :
    CONVERSION: up to 384k, 32bit PCM, native DSD
    up to DSD256, DXD, 130dB Dynamic Range
    MQA HI-RES DECODER: built in certified hardware
    MQA (tm) decoder
    DIGITAL INPUTS: USB2 Class2 (OSX, Linux driverless,
    all formats), AES/EBU (PCM up to 192k, up to DSD64 DOP), 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), Toslink/ADAT 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), SDIF3 DSD up to DSD256
    CLOCK: “Mytek Femtoclock Generator (tm)” 0.82ps internal jitter, Wordclock Input and Output (allows stacking multiple units for multichannel operation,
    includes mch DSD)
    ANALOG OUTPUTS: RCA, balanced XLR, simultaneous,
    50 Ohm impedance
    HEADPHONE OUTPUTS: Reference High Current,
    High transient Headphone Amp, 500mA, 6 Watts,
    dual headphone jacks, designed to drive hard to
    drive headphones.
    BUILT-IN ATTENUATOR: Choice of 1dB step analog attenuator, separate for main out and head- phones,
    1dB step digital 32 bit attenuator and purist relay bypass.
    BUILT-IN ANALOG PREAMP: Line level input or
    Phono M/M, M/C input, relay controlled.
    AUDIO INTERFACE FUNCTION: All digital inputs can
    be routed into computer via USB2. Allows connection
    of external digital sources such as CD Players and
    digitizing ADCs.
    REMOTE: Included, universal remote capable
    FIRMWARE: Upgradable via USB Control panel
    WORLDWIDE POWER SUPPLY
    OPTIONAL DC/BATTERY POWER INPUT: 12VDC
    DIMENSIONS: WxDxH=8.5x8.5x1.74”=216x216x44mm
    WEIGHT: 4lbs, 2kg
    WARRANTY: 2 years
    Siste redigert av Moiz Audio; 22.09.2016 kl. 13:40.
  2. Antall kommentarer 3
    Æresmedlem Distinctive's Avatar
    Dec 2006
    Tagget i
    14 Innlegg
    Album
    Kjekk sak, ingen tvil om det.
  4. #3
    Hifi-entusiast Volund's Avatar
    May 2012
    OSLO
    Tagget i
    0 Innlegg
    Spennende, hvordan er mulighetene for hjemlån?
  5. #4
    Bransjemedlem Moiz Audio's Avatar
    Aug 2007
    Tagget i
    1 Innlegg
    Se min butikk
    Klikk her
    Torget
    54
    Sitat Sitat fra Volund Se Innlegg
    det er alltid mulighet for hjemlån
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
