Game over. Mytek Brooklyn MQA ready DAC.
The Absolute sound har testet Mytek Brooklyn DAC. Klikk på bildet for å lese testen.
Pris: 18500 Inkludert frakt.
For eiere av Stere-192 DSD DAC tilbyr vi en inbyttedeal på 12000 NOK + frakt
F
or bestilling: ring 93047149, send mail til info@moiz.no eller PM
Fra produsentens hjemmeside: mytekdigital.com
Brooklyn is a reference USB2 DAC, line and phono analog preamplifier and a reference headphone amplifier.
It integrates digital and vinyl hi-res playback for reference listening on headphones and speakers.​
SPECIFICATIONS :
CONVERSION: up to 384k, 32bit PCM, native DSD
up to DSD256, DXD, 130dB Dynamic Range
MQA HI-RES DECODER: built in certified hardware
MQA (tm) decoder
DIGITAL INPUTS: USB2 Class2 (OSX, Linux driverless,
all formats), AES/EBU (PCM up to 192k, up to DSD64 DOP), 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), Toslink/ADAT 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), SDIF3 DSD up to DSD256
CLOCK: “Mytek Femtoclock Generator (tm)” 0.82ps internal jitter, Wordclock Input and Output (allows stacking multiple units for multichannel operation,
includes mch DSD)
ANALOG OUTPUTS: RCA, balanced XLR, simultaneous,
50 Ohm impedance
HEADPHONE OUTPUTS: Reference High Current,
High transient Headphone Amp, 500mA, 6 Watts,
dual headphone jacks, designed to drive hard to
drive headphones.
BUILT-IN ATTENUATOR: Choice of 1dB step analog attenuator, separate for main out and head- phones,
1dB step digital 32 bit attenuator and purist relay bypass.
BUILT-IN ANALOG PREAMP: Line level input or
Phono M/M, M/C input, relay controlled.
AUDIO INTERFACE FUNCTION: All digital inputs can
be routed into computer via USB2. Allows connection
of external digital sources such as CD Players and
digitizing ADCs.
REMOTE: Included, universal remote capable
FIRMWARE: Upgradable via USB Control panel
WORLDWIDE POWER SUPPLY
OPTIONAL DC/BATTERY POWER INPUT: 12VDC
DIMENSIONS: WxDxH=8.5x8.5x1.74”=216x216x44mm
WEIGHT: 4lbs, 2kg
WARRANTY: 2 years
Volund
OSLO
Spennende, hvordan er mulighetene for hjemlån?
Moiz Audio
Moiz Audio sine annonser
SPL Phonos RIAA test i The Ear
  • 1
Link til test: https://the-ear.net/review-hardware/spl-phonos-mm-mc-accurate-vinyl-sound/ SPL Phonos RIAA leverer en dynamisk og livlig lydopplevelse preget av nøytralitet og presisjon. Teknisk...
Lab12 DAC1 Reference
  • 2
PÅ LAGER IGJEN! Lab12 DAC1 Reference er et imponerende produkt som er konstruert rundt 8 Philips multibit DAC-chips i en parallell konfigurasjon og 6922 trioderør på utgangen. DAC1 Reference...
Burson Audio Soloist Voyager
  • 3
Flaggskip Amp fra Burson Audio er nå tilgjengelig i Norge Dette er en en Klasse-A, symmetrisk Dual Mono design og Fullbalansert . En strømsterk forsterker som leverer 10 Watt i klasse A...
Burson Audio diskret OP-amper: Vivid V7 Pro vs Vivid V6 (forrige generasjon)
  • 6
Andy skifter Vivid V6 opampene i Burson Audio Playmate 2 til nyeste Vivid V7 PRO, og forklarer forskjellene han hører. V7 Vivid PRO op-amps er designet for å oppnå maksimal oppløsning og...
BURSON AUDIO V7 OP-AMPER ! ! ! ! ! !
  • 8
BURSON AUDIO PRODUKTER KAN NÅ OPPGRADERES! Burson Audio's nyeste generasjon av Diskre OP-amper er nå tilgjengelig! v7 serien kombinerer banebrytende kretsløp og overlegen lyd. Den kompakte...
Audiophile.fr tester LAB 12 Gordian
  • 3
Tidligere omtalt hos stereopluss https://viewer.joomag.com/stereo-7-2023/0397186001696598323/p58?short AB12 Gordian er en strømrenser som består både av passive og aktive filtre. Analysekretsen...
