En integrert forsterker som kan de meste, som ser strålende ut og som låter fenomenalt!
Peachtree er et perfekt utgangspunkt for de som ønsker å bygge seg et hypermoderne stereoanlegg i stuevennlig innpakning.
Highlights
"The new Peachtree Audio nova150 integrated amplifier is a wonderful example of what better engineering and manufacturing can do for sound quality." Computer Audiophile
"One could be forgiven for buying one on looks alone. Inside though, this model is all wheat and no chaff. A DAR-KO Award is hereby assigned without second thought." Digital Audio Review
For mer informasjon se her:
PEACHTHREE NOVA 150 - Oslo Hifi Center
Highlights
- ESS Reference 9018K2M Sabre DAC
- 32-Bit/384kHz PCM and 5.6MHz DSD (double-DSD) compatibility
- New generation ICEPower amplification - 150 watts per channel
- Extensive internal grounding
- Designed by a world-class engineering team
- Asynchronous USB, Coax and (2) Optical inputs
- Asynchronous iOS input for direct digital input from Apple Lightning devices - with exclusive Peachtree DyNEC (Dynamic Noise Elimination Circuit) technology.
- Phono (MM) input
- Home Theater Bypass
- Loop feature to add an external tube buffer, EQ or other processor into the signal path
- Pre-Out for use as preamp/DAC or with subwoofer
- Discrete, custom-designed headphone amplifier
- Optional Wi-Fi module to be announced
- Available in Gloss Ebony Mocha and Piano Black
- Made in North America
