Resultater 1 til 7 av 7
Abonnér på denne artikkelen
  1. Nyheter fra C.E.C. Nytt drivverk og matchende DAC.
    6 Kommentarer Av Endpoint Audio - 23.08.2016 12:43
    CEC TL3 som har fått en rekke fantastiske tester - nå sist i Audio Fidelity - er erstattet med Drivverket TL5. Etter en rekke vurderinger anså CEC at TL5 var nær like god som TL3 og har valgt å fase ut denne til fordel for TL5.
    CEC har også lansert ny DAC - DA5 til 39.990,-
    TL5: 24.990,- På lager i sort og sølv finish.
    Navn:      tl5_img_800.jpg
Visninger: 567
Størrelse: 26.1 KbNavn:      tl5_rear_800.jpg
Visninger: 588
Størrelse: 78.3 KbNavn:      tl5bk_img_800.jpg
Visninger: 618
Størrelse: 30.3 Kb
    Since CEC introduced world's first Belt-Drive CD Transport in 1991, a lot of music lovers have enjoyed its rich musical sound, which CEC continues to improve on. A heavier stabilizer brings a more stable rotation of the disc and the Belt-Drive system eliminates the affects of vibration and electromagnetic noise caused by the motor rotation.
    In order to read the signal recorded with Constant Linea Velocity (CLV) on CD, rotation speed should be slowed down as it goes to the outside. Usually the spindle motor controls the variation of speed. All CD players and transports place the spindle motor beneath the turntable for CD and the motor shaft works as the turntable center, this is called directdrive system. Stable and accurate rotation requires a bigger torque of motor itself, which inevitably creates certain vibration and the electromagnetic noise. In CEC TL 5 the spindle motor is placed independently from the center shaft and vibration as well as electromagnetic noise effect to the CD are thus minimized. A heavy CD stabilizer provides bigger inertia of turntable and achieves a stable and smooth rotation of discs. Smaller torque motor and longer distance from the motor to the center shaft (turntable) create the ideal fundamentals of music reproduction.
    The new CEC TL 5 features multiple digital outputs: AES/EBU, COAXIAL and TOSLINK. The shortest possible signal pass and stability of signal quality have been maintained by direct mounting of all terminals to the single circuit board. Superior Fluorescent display can be dimmed and even disconnected.
    By placing the turntable shaft in the center of the top loading open space the rubber belt replacement is now done with ease on the CEC TL 5.
    The word about the musical cohesion, the rich detail and emotionally gripping "analogue-like" sound got out very quickly. No other CD drive has sounded so analogue to this day. There has seldom been higher quality compact disc playback in this price class!
    With the belt-driven CEC TL 5 in the system, one can benefit from the advantages of this type of drive. The newest CD belt drive by CEC helps improve the tonal progression.
    Test reports in international magazines as well as the testimony of our satisfied customers worldwide confirm
    that we have achieved our musical objective: music reproduction on its highest level.
    tom@endpoint-audio.com
    47832922
    Vedlagte bilder
    Siste redigert av Endpoint Audio; 26.08.2016 kl. 10:44.
  2. Antall kommentarer 6
    Overivrig entusiast P.O.M.'s Avatar
    Mar 2004
    Tagget i
    0 Innlegg
    Ja, i dag fikk jeg i hus dette CEC TL5 drivverket og har nå spilt noen timer på det.
    Dette var faktisk en stor overraskelse, at det var stor forskjell i lyden med dette drivverket kontra den CD spilleren jeg til nå har brukt som drivverk var positivt overraskende!
  4. #3
    Hifi-entusiast Janpe's Avatar
    Aug 2015
    Tagget i
    0 Innlegg
    Underskriver på at CEC er fenomenalt gode produkter. CD' en er definitivt ikke død.
    JP
  5. #4
    Bransjemedlem Endpoint Audio's Avatar
    Apr 2013
    Tønsberg
    Tagget i
    1 Innlegg
    Se min butikk
    Klikk her
    Torget
    Takk for tilbakemeldingene. CEC er særdeles vellydende produkter og de innfrir. Snakket akkurat med en kunde som har en CD5 med innganger til den integrerte DAC'en. Han har testet flere eksterne DAC'er for å se om det var noe å hente, men konkluderte med at CD5 har en eksepsjonelt god DAC innebygd.
    Helt enig med deg JP - cd'en er ikke død. Mange av oss har en god bunke - og personlig så foretrekker jeg det fysiske mediet over strømming. Jeg syns det låter bedre, og har funnet ut at drivverk har utrolig mye å si.
  6. #5
    Helt fersk
    Apr 2014
    Tagget i
    0 Innlegg
    Jeg kjøpte drivverket CEC TL3N og DA 3N hos Tom Egil for en tid tilbake og kan ikke annet si enn at jeg er meget fornøyd med både handel og produkt. Jeg er også glad i det fysiske mediet. Det at man bruker litt tid på handlingen med å sette på en plate, føle forventningen og den velvære man fornemmer når man setter deg godt til rette.
    Det blir litt mer nytefullt å gjøre den fysiske handlingen. Bruker også strømming jeg, men jeg finner ikke riktig den samme roen da det tidvis blir for lett å fortrenge de "dårlige" låtene. Det handler for meg mye om å finne roen...
    CEC er solide, ærlige og nærmest skuddsikre produkter med en god signaleffekt, med det mener jeg at de ikke er prangende på noen måter. Drivverket TL3N er for meg en nytelse å bruke og det gir et " rolig analog" anstrøk til musikken. Jeg vet ikke hvorfor, men slik oppfatter jeg lyden når jeg spiller fra TL3N kontra å strømme musikk.
    A.V.
  7. #6
    Æresmedlem impulse's Avatar
    Feb 2006
    Hølen
    Tagget i
    1 Innlegg
    Jeg har vel sagt en del om hvor gode disse drivverkene er i siste Fidelity, og har ikke så mye å legge til. Hos meg var det en virkelig forbløffene oppgradering. Men de trenger noen timer for å gå seg helt til, så du blir nok enda mer fornøyd om litt, POM !
    Siste redigert av impulse; 24.08.2016 kl. 12:54.
  8. #7
    Mar 2004
    Tagget i
    0 Innlegg
    Ja, og når det verste oppgraderingssjokket har gitt seg er det kanskje på tide å «snuse på» en slik svindyr CEC-Wellfloat plattform til å ha spilleren på…
    Navn:      audio_asb3454wf.jpg
Visninger: 332
Størrelse: 12.7 Kb
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
