VPI REFERENCE platespiller som kan monteres med flere armer.
Navn:      VPI AVENGER  for HIFI SENTRALEN.jpg
Visninger: 605
Størrelse: 59.9 Kb
The VPI Avenger table was originally a project started by Harry over 12 years ago. In the process of the design the project was dropped in mid-production due to excessive demand by HR-X customers which left the design and proto-type chassis to be mothballed. The good news about the abandoned design is Harry instead shifted his focus into starting and completing the VPI Classic Turntable.
Shortly after the development of the Prime, and while cleaning out the warehouse in preparation for a dealer training event, the forgotten Avenger and its designs were re-discovered! The working name was the "Tri-Pod Project". Being newly motivated, Harry has finally put in motion the table that will be his master piece! The unique iterations that had been crafted from the original process were completed as Special Editions.
The Table:
The VPI Avenger chassis is three layers of bonded acrylic/aluminum/acrylic, with damping material between layers, locked in by 3 isolation steel corner posts, 3 bolts, and the massive bearing assembly. The corner posts which hold the tonearms (up to three will fit) have adjustable machined knobs giving the user the ability to easily raise and lower the height to level the table. The corner posts connect to the cone stabilizers which sit in a machined Delrin/ball bearing isolation base reminiscent of the same used on the Prime turntable. Fully adjustable armboards are made from 5/5” 6061 aluminum for rigidity and grounding. The table can mount up to three arms, any manufacture's brand, and any length!
Available Upgrades:
  • Periphery Ring clamp for the ultimate in record warp reduction
  • Synchronous Drive System (SDS) for the utmost accuracy in motor speed and fine speed adjustments.
  • Avenger Motor
  • Avenger Feet
  • JMW-12-3D
  • JMW-12-3DR
  • Additional JMW Tonearms
    Additional Armboards
Pris VPI AVENGER : Kontakt oss !
Lyric HiFi , Torggata 28 , 0183 Oslo
Tlf 22411984 mellom kl 12.00-17.00
Velkommen
Tor Aamodt Haug
