VPI AVENGER mye benyttet i LAS VEGAS kontakt LYRIC HIFI
VPI REFERENCE platespiller som kan monteres med flere armer.
The VPI Avenger table was originally a project started by Harry over 12 years ago. In the process of the design the project was dropped in mid-production due to excessive demand by HR-X customers which left the design and proto-type chassis to be mothballed. The good news about the abandoned design is Harry instead shifted his focus into starting and completing the VPI Classic Turntable.
Shortly after the development of the Prime, and while cleaning out the warehouse in preparation for a dealer training event, the forgotten Avenger and its designs were re-discovered! The working name was the "Tri-Pod Project". Being newly motivated, Harry has finally put in motion the table that will be his master piece! The unique iterations that had been crafted from the original process were completed as Special Editions.
The Table:
The VPI Avenger chassis is three layers of bonded acrylic/aluminum/acrylic, with damping material between layers, locked in by 3 isolation steel corner posts, 3 bolts, and the massive bearing assembly. The corner posts which hold the tonearms (up to three will fit) have adjustable machined knobs giving the user the ability to easily raise and lower the height to level the table. The corner posts connect to the cone stabilizers which sit in a machined Delrin/ball bearing isolation base reminiscent of the same used on the Prime turntable. Fully adjustable armboards are made from 5/5” 6061 aluminum for rigidity and grounding. The table can mount up to three arms, any manufacture's brand, and any length!
Available Upgrades:
  • Periphery Ring clamp for the ultimate in record warp reduction
  • Synchronous Drive System (SDS) for the utmost accuracy in motor speed and fine speed adjustments.
  • Avenger Motor
  • Avenger Feet
  • JMW-12-3D
  • JMW-12-3DR
  • Additional JMW Tonearms
    Additional Armboards
Pris VPI AVENGER : Kontakt oss !
Lyric HiFi , Torggata 28 , 0183 Oslo
Tlf 22411984 mellom kl 12.00-17.00
Velkommen
Tor Aamodt Haug
LYRIC HIFI
LYRIC HIFI sine annonser
SOLIDSTEEL eksklusiv import og salg tilbake hos LYRIC HIFI , Torggata 28 Oslo
  • 1
Since their introduction in 1991, Solidsteel audio tables have established a new level of technical and aesthetic refinement for audio and video component support and isolation...
Nye STAX SRS-5100 = SR-L500 elektrostat hodetelefon & SRM-353X driver ankommet
  • 5
STAX SR-L500 elektrostat hodetelefonen og SRM-353X transistor driver/forsterkeren bringer musikk til ørene med detaljer og kvalitet som er fantastisk med stor opplever en fyldig og dyp...
Helt ny modell ProAc DB-1 ankommet. Kom, lytt og glem hverdagen ! LYRIC HIFI
  • 15
Stewart Tyler's magi igjen på sitt beste. Ord blir overflødig, må oppleves ! Herlighetene kan erverves for kr 24 950 pr par for Standard finish og kr 27 560 pr par for Premium finish. For...
WhestAudio THREE Signature riaa - NY ALVORLIG "TRUSSEL" hos LYRIC HIFI Torggt 28
  • 4
WhestAudio THREE Signature riaa - NY ALVORLIG "TRUSSEL" hos LYRIC HIFI Torggt 28 For MC pick-up’er med høy oppløsning Som alle Whest Audio' s design har whestTHREE Signatureblitt laget for...
Vi inviterer til demokveld med FOCAL La SCALA mk 1 tirsdag 2. fra 16.00-20.00
  • 2
Seansen vil foregå i våre lokaler i Malmskriverveien 11 eller Torggata 28 Vi informerer nærmere om hvor dette vil skje avhengig av hvor mange melder ifra at de vil komme. Mail påmelding om du vil...
Vi inviterer også til demokveld med ProAc D-48R torsdag 28. januar fra 16.00-20.00
  • 8
Seansen vil foregå i våre lokaler i Torggata 28 med enkel servering og den største musikalske opplevelse ! ProAc har i alle år fått kun glimrende skussmål av musikkglade brukere som ikke så...
