Resultater 1 til 13 av 13
Abonnér på denne artikkelen
  1. `BRYSTON BDP-2.. få bedre analogfølelse av digitale filer- OPPLEVES hos LYRIC HIFI
    12 Kommentarer Av LYRIC HIFI - 17.01.2016 21:11
    Navn:      BRYSTON BDP_2 silver skrå for hifi sentralen P1 X.jpg
Visninger: 932
Størrelse: 27.5 KbNavn:      BRYSTON BDP_2 silver bakfra hifi sentralen P2 X.jpg
Visninger: 1016
Størrelse: 29.8 Kb
    The Bryston BDP-2 is a dedicated player for high resolution digital audio files. Employing a modified Linux OS optimized to provide the highest quality audio performance, the BDP-2 will play high resolution audio files (up to 192k/24b) from digital storage devices without compromise. The BDP-2 features an improved power supply, custom Intel Atom powered motherboard, additional input options, and eight times more system memory than the BDP-1.
    Now included is a new proprietary Integrated Audio Device card created in-house which provides improved performance, integrated output and sound processing, and is powered directly by a high quality linear power supply.
    Inputs: 6x USB 2.0, 1x eSATA, 2x Gigabit Ethernet (RJ-45)
    Outputs: SPDIF (BNC), AES/EBU (XLR)*, USB**
    Control: 2x RS-232 (DB9)
    Audio Formats: AIFF, FLAC, WAV, MP3, M4A, OGG
    Features:
    • Dedicated high resolution digital audio player
    • Playback from USB flash drives, as well as USB and eSATA hard disk drives (HDD)
    • Custom Intel Atom Powered Motherboard
    • Eight times more system memory then the BDP-1.
    • Improved power supply delivering over 5 amps.
    • Multiple control options (iPhone, iPod Touch, iPad, Android OS, and PC)
    • User upgradable firmware
    • NAS Connectivity supported
    • UPnP/DNLA Server supported
    • Requires external DAC (see External DAC in Digital Audio)***
    Features Continued:
    • RS-232 serial data port for remote control via Crestron, AMX or similar control systems
    Options:
    * Via the integrated ice1724 Chipset
    ** Via built in software decoders. USB output requires S1.70 firmware or greater and a DAC that supports standard class 2 USB audio drivers.
    *** External DAC required for full 192K/24b performance, but the BDP-1 is also compatible (up to 96K) with the optional DAC modules in BP26, BP6, BP16 and BP17 Preamps, or B60R, B100 and B135 Integrated Amplifiers.
    Pris for BDP-2 inkl 25% MVA : NOK 33 680
    Lyric HiFi , Torggata 28 , 0183 Oslo
    Tlf 22411984 mellom kl 12.00-17.00
    Velkommen
    Tor Aamodt Haug
    Siste redigert av LYRIC HIFI; 17.01.2016 kl. 21:19.
  2. Antall kommentarer 12
    Overivrig entusiast oen's Avatar
    Mar 2010
    Tagget i
    0 Innlegg
    Har dere ikke ansatte som kan oversette til Norsk?
  4. #3
    Oct 2007
    Tagget i
    0 Innlegg
    Hei Oen,
    Jeg tar det for gitt at alle som er på dette nivået mht utstyr har de engelskkunnskaper som trengs.
    Trenger du norsk oversettelse, gå inn på siden til Bryston og la Google oversettelses-program gjære jobben og vips har du norsk.
    Ha en fortsatt god kveld.
    mvh Tor
  5. #4
    Hifi-entusiast
    Jul 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra LYRIC HIFI Se Innlegg
    Hei Oen,
    mvh Tor
    Det var da et arrogant svar!
  6. #5
    Hifi Freak E.I.A.'s Avatar
    Jul 2004
    Tagget i
    1 Innlegg
    Sitat Sitat fra sigma 6 Se Innlegg
    Hei Oen,
    mvh Tor
    Han fikk svar på det han spurte om
    Google translatør er et glimrende redskap for de som ikke kan engelsk.
  7. #6
    Hifi Freak Kanutus's Avatar
    Nov 2014
    Nesodden
    Tagget i
    0 Innlegg
    Hei Oen,
    mvh Tor
    Hvis du leser svaret én gang til, med god vilje, så er det vel ingenting der som faktisk er arrogant? Muligens er det snev av irritasjon der, da det strengt tatt er et litt småfrekt spørsmål å stille (etter min mening) ...
  8. #7
    Hifi Freak barathsec's Avatar
    May 2012
    Der hvor gjøken alene galer i full Stereo
    Tagget i
    0 Innlegg
    Noen blir aldri helt fornøyde, regner med at om denne hadde vært av interesse så ville vel google sin oversetter allerede ha blitt brukt, hvis ikke så kan den bli brukt nå..! hvis ikke så er det bare å lete videre etter andre ting å sette "fingeren" på..!
  9. #8
    Hifi Freak skorob's Avatar
    May 2012
    Brumunddal
    Tagget i
    1 Innlegg
    Torget
    Engelsk må anses som innafor .
  10. #9
    Hifi Freak yngvejos's Avatar
    Sep 2010
    Tagget i
    0 Innlegg
    Hei Oen,
    mvh Tor
    Her strekker vi oss langt for potensielle kunder.
    Hvis du ikke berhersker engelsk (teknisk sådan), er du for dum til å kjøpe dette produktet.
  11. #10
    Hifi Freak S. Lieng's Avatar
    May 2014
    Tagget i
    0 Innlegg
    Sitat Sitat fra yngvejos Se Innlegg
    Hei Oen,
    mvh Tor
    Det blir vel en prioritering av tid. De som vurderer å bruke over 30 lapper på en dac vil vel ta en tur innom butikken, eller i det minste en tlf for å få mer info om produktet.
  12. #11
    Hifi-entusiast
    Feb 2011
    Østlandet
    Tagget i
    0 Innlegg
    Spennende produkt! Hva ligger forresten BP26 og 4bsst2 på? Forøvrig greit med engelsk. Verre med Setswana og andre språk du ikke finner på Google translate..
  13. #12
    Hifi-interessert monitor's Avatar
    Jun 2007
    Mysen
    Tagget i
    0 Innlegg
    We wonen in Noorwegen en dan is het natuurlijk zo dat luiheid geen excuus is voor het ontgaan van produktinformatie op zijn noors.
    De verkoper is een grote lul als hij niet tegen dit soort kritiek op een fatsoenlijke manier reageert.
    DUS: In NOORWEGEN spreken we noors, en dan zijn het alleen klootzakken als mij die dan iets in een andere taal voorschotelen...
  14. #13
    Jan 2008
    Tagget i
    3 Innlegg
    Det er krevende å være spesialistleverandør i denne bransjen. Ofte enkeltpersoner eller små foretak som gjør sitt beste i en tid med internetthandel og redusert kundegrunnlag. Vis gjerne respekt for at disse må prioritere tiden sin. Hvilken service er du forresten mest villig til å betale for? - personlig service og mulighet for å lytte og sammenligne produkter i en hyggelig atmosfære, eller oversettelse av et høyt antall produktinformasjonsskriv inkludert kvalitetssikring? - noen få er kanskje villig til å betale for begge deler, men de fleste kundene foretrekker å kun betale for det første. Mistenker på toppen av det hele at de mest kritiske til engelsken ikke nødvendigvis legger igjen mest penger hos slike forhandlere. Norge er et lite land med betydelig innslag av handel med utlandet og gode engelskkunnskaper. Legg til at vi snakker om nisjeprodukter og entusiastforhandlere, så forstår dere hvor jeg vil hen.
    Sitat Sitat fra monitor Se Innlegg
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
