Acoustical Systems lanserte nylig sin nye tonearm Aquilar.
Denne er basert på teknologien til Axiom, men til halve prisen.
Pris: 75.000,-
Beskrivelse fra konstruktøren:
tom egil
47832922
tom@endpoint-audio.com
Endpoint Audio | – the ultimate destination for audio
Pris: 75.000,-
Offering many of the superior choice and expensive materials, as well as most of the unique technical key solutions which made the AXIOM in its performance easily standing heads above all competition.
the AQUILAR features:
- 10” effective length (suitable for easy mount on ALL turntables - including Basis, AirForce Two and SME 20/30 etc)
- very easy and swift set up
- customized 3D-alignment template
- HD18 tungsten carbide counterweight - same as AXIOM
- unique acoustical-systems titanium/carbon-hybrid arm wand - same as the AXIOM
- precision leveling of bearing plane independent of arm board / turntable - same as AXIOM
- adjustable SRA, VTA, Azimuth, Overhang and Offset angle at headshell - same as AXIOM
- VTA on-the-fly - same as AXIOM
- non-touch magnetic Antiskating on-the-fly - same as AXIOM
- dynamic anti skating following the tangential curve - same as AXIOM
- design based on unique UNI-DIN geometry - available only in AXIOM and AQUILAR
- inner wiring is aged German origin fine 5N pure silver litz wire - same as AXIOM
- available with 2 terminal options:
direct-to-phono 1.2 m length phono lead
or
male DIN 5-pole connector
- available in 2 fine finishes:
black satin matt
or
ceramic-alloy bright silver matt (note: this looks just great - especially on Kronos, TechDAS AFO, TechDAS AFT and Sperling turntables!)
- available in 2 mounting versions:
with flat top mount plate (same as Tri-Planar , Jelco or DaVinci)
or
drop-in replacement for standard SME-mounting plate
Please note: the AQUILAR can drop-in replace TriPlanar, DaVinci, Jelco or Graham Supreme without any alternation to customer’s pre-drilled arm board!!
or
black satin matt
or
or
tom egil
47832922
