Du inviteres til store musikkopplevelser fra ProAc D-48R høyttalerne.
Disse er bestykket med 2 stk basselementer ned "carbon fiber pulp" cone og bånddiskant.
Det er meget vanskelig å få integrert og tilpasset elementer mot bånddiskant
slik at man får en overgang mot mellomtonen som føles sømløs.
Info sakset fra nettet :
The ProAc D48R is identical to the D48, however utilises a ribbon tweeter.
ProAc have improved the mid-range detail and a opened up a cleaner, faster and more extended bass response. A new studio monitor quality bass driver was designed for the D48, featuring a special impregnated cone and mid frequencies tuned by a cap of greater size than standard. This gives the new unit greater mid-range detail along with excellent bass control giving a tighter and more extended response.
The two new bass drivers are each loaded through ProAc's special floor loading with side vents, this makes the loudspeaker easier to place and reacts less to surroundings. The two bass units are then seamlessly mated to our ribbon or dome tweeter depending on your preference. With such a large slim floor standing design the sound stage is superb being very large and with pinpoint imagery. Another achievement for the D48 is its ability to create large orchestral works as well as heavy rock music.
The D48 has a high quality filter network designed by Stewart Tyler comprising of the finest components, ProAc cable on a special board. The filter is also split for bi-amping and bi-wiring. This is one of the best designs from ProAc and should please all audio files regardless of their taste in music.
ProAc have moved away from the carbon fibre cone material utilised on the D40, instead opting for a carbon fibre pulp which delivers improved midrange frequency reproduction as well as tighter bass with less low frequency hangover.
These differences give the listener a more detailed, open midrange and a more expansive soundstage. Also, the leading edge of bass instruments is more audible with less muddling in comparison to other carbon fibre based drivers.
Vi kan demonstrere med både rør og transistor etter ditt ønske, men de står p.t.
oppkoplet med BRYSTON forsterkersett.
Kom og hør hva legendariske Stewart Tyler har fått til med disse.
Avtal når du ønsker å komme.
Velkommen !
Tor Aamodt Haug
LYRIC HIFI
Torggata 28 -0183 Oslo
tlf 22411984
mail : tor@taaimport.no
Velkommen !
Tor Aamodt Haug
LYRIC HIFI
tlf 22411984
142.5 KB Visninger: 1.807
