Til eiere av BRYSTON BDP-2: NYTT LYDKORT , kr 5800 - ta kontakt, Lyric Hifi
Melding fra BRYSTON :
We have been working on a Bryston proprietary“Integrated Audio Device” card with much improved specifications to replace thecurrent two-piece ‘Soundcard’ and ‘SPDIF interface module’ (AES/BNC) utilizedin our current BDP-2 Digital Player.
BENEFITS:
• No reliance on the quality level of third partyproducts or having to modify said products
• Improve the performance by hand selecting andtesting all the components in house
• Eliminates 3 connection points
• Integrates the output module and the soundprocessing section into one circuit instead of two.
• The Bryston audio device is directly powered by thehigh quality linear power supply rather than the motherboard.
James Tanner
Bryston
mvh Tor AAmodt Haug
LYRIC HIFI
Torggata 28- 083 Oslo
mail : info@taaimport.no
tlf : 2241984
Ketil
Min opplevelse er at BDP-2 modellen min gir bedre lydkvalitet med USB tilkoblingen. Men dette kan nok ha å gjøre med USB grensesnittet på DAC'en min er av høy kvalitet. Men vil det oppgraderte lydkortet gi bedre lyd enn USB igjen? Tviler litt.
LYRIC HIFI
Hei Ketil,
Kortet er nylig mottatt og sender ut til kunder nå og har ikke prøvd det her selv ennå.
Bryston har aldri levert "fake" , så du burde kanskje anskaffe dette seinere til din BDP-2.
Legger ved kommentar mottatt til BRYSTON fra studio som har installert kortet i sin BDP-2 mvh Tor
MEMO: To All Bryston Customers
SUBJECT: Bryston IAD Sound Card TEST
July 2015
Hi James
We tested your new Bryston ‘Integrated Audio Device’ in our BDP-2 digital player against the old card on our ‘Cowboy Junkies Mastering Project.’
The exact same Cowboy Junkies Trinity Sessions file played out via AES/EBU of the original BDP-2 audio card into the BDA-2 D/A Converter with up sampling on.
This was then recorded ‘analogue’ at 176.4khz_24bit using the DAD (Digital Audio Denmark) AX24.
E ROOM MASTERING
We then replaced the old sound card with the Bryston IAD and the exact procedure was repeated. The 2 files are aligned and phased match on parallel tracks and played, switching A & B between the two.
No Contest, empirically proven, Night and Day Difference. As if a wool sweater has been removed!!
The High frequency definition is outstanding, in fact, it is scary how rolled off the old card top end was. Slight improvement in bass transients. Sound stage was much more stable. Less sibilance on voice. Upper midrange was more open. Depth perception much deeper and wider (better resolution of high frequency reverb reflections)
Congrats James
TRINITY SESSIONS
Yours Truly
Peter J. Moore
President
Ketil
Nei, "fake" er det sikkert ikke. Min spørsmålsstilling gikk mer på lyd ut via lydkort kontra lyd ut via USB. Etter å ha gått fra å koble med AES/EBU til å koble med USB, synes jeg sistnevnte stakk av med seieren. Ved å koble med USB synes jeg lyden var mer fokusert og jeg merket jeg ble mer engasjert av lyttingen. Som kjent er lydkortet i BDP-2 ute av signalveien når man kobler via USB. Spørsmålet blir da om det nye lydkortet kan trumfe tilkobling via USB. Svaret er nok at dette blir individuelt fra anlegg til anlegg da implementeringen av USB grensesnittet på DAC også spiller inn. Ifølge konstruktøren av min DAC er denne av høy kvalitet og skal være bedre enn AES/EBU implementasjonen på denne DAC'en, så derfor er jeg litt i tvil om det i mitt tilfelle ville vært en oppgradering. Men kjekt å ha i bakhånd hvis jeg skulle ønske det engang ihvertfall.
LYRIC HIFI
Hei Ketil,
Beklager , gikk litt raskt ut.
Hvilken DAC har du ?
mvh Tor
E.I.A.
USB er nok og foretrekke på de fleste kvalitetsdacer med asyncron USB tilkobling.
På feks forrige modell Bryston Bda1 el. med begrenset USB, er det nok bedre med AES/EBU.
Hadde selvfølgelig vært spennende og teste om AES nå trumfer USB også på nyere dacer :)
Inter
Tor, jeg kommer innom efter sommerferien og skal nok ha en, da jeg bruker AES/BNC primært.
Åsmund
LYRIC HIFI
LYRIC HIFI sine annonser
SOLIDSTEEL eksklusiv import og salg tilbake hos LYRIC HIFI , Torggata 28 Oslo
  • 1
Since their introduction in 1991, Solidsteel audio tables have established a new level of technical and aesthetic refinement for audio and video component support and isolation...
Nye STAX SRS-5100 = SR-L500 elektrostat hodetelefon & SRM-353X driver ankommet
  • 5
STAX SR-L500 elektrostat hodetelefonen og SRM-353X transistor driver/forsterkeren bringer musikk til ørene med detaljer og kvalitet som er fantastisk med stor opplever en fyldig og dyp...
Helt ny modell ProAc DB-1 ankommet. Kom, lytt og glem hverdagen ! LYRIC HIFI
  • 15
Stewart Tyler's magi igjen på sitt beste. Ord blir overflødig, må oppleves ! Herlighetene kan erverves for kr 24 950 pr par for Standard finish og kr 27 560 pr par for Premium finish. For...
WhestAudio THREE Signature riaa - NY ALVORLIG "TRUSSEL" hos LYRIC HIFI Torggt 28
  • 4
WhestAudio THREE Signature riaa - NY ALVORLIG "TRUSSEL" hos LYRIC HIFI Torggt 28 For MC pick-up’er med høy oppløsning Som alle Whest Audio' s design har whestTHREE Signatureblitt laget for...
Vi inviterer til demokveld med FOCAL La SCALA mk 1 tirsdag 2. fra 16.00-20.00
  • 2
Seansen vil foregå i våre lokaler i Malmskriverveien 11 eller Torggata 28 Vi informerer nærmere om hvor dette vil skje avhengig av hvor mange melder ifra at de vil komme. Mail påmelding om du vil...
Vi inviterer også til demokveld med ProAc D-48R torsdag 28. januar fra 16.00-20.00
  • 8
Seansen vil foregå i våre lokaler i Torggata 28 med enkel servering og den største musikalske opplevelse ! ProAc har i alle år fått kun glimrende skussmål av musikkglade brukere som ikke så...
