Ingen vårmesse eller kampanje, men vi gir deg muligheten til å oppleve en av verdens beste "stativhøyttalere". I Asker, etter nærmere avtale. Vi har Kaiser Kawero Chiara på demo, her er noen detaljer fra produsentens sider::
The Chiara high performance stereo loudspeaker features sophisticated engineering, state-of-the-art
materials and high tech manufacturing processes to minimize structural vibration, offering uncolored tonal
coherence and a robust sound previously unattainable in a compact loudspeaker of this size.
It is the smallest loudspeaker in the Kaiser Kawero speaker range, all manufactured from Panzerholz, a
high tech natural wood-based laminate engineered in Germany. Panzerholz is incredibly dense: it sinks in
water, offers the rigidity of steel, and also boasts some of the best vibration damping characteristics in the
world. In fact, as a side-effect of this performance, it turns out that this loudspeaker is bulletproof.
Hardships in working this extremely hard material are overcome by careful tooling and handling techniques.
Features
• Tankwood / rubber / glass fibre high pressure
sandwich cabinet without parallel surfaces
• Bass and midrange 4th order alignment design
through rear-firing passive radiator (custom made
Scan Speak Illuminator unit)
• Custom paper and carbon sandwich cone driver
from Scan-Speak Denmark
• Extremely fast custom made Mundorf AMT tweeter
• Duelund CAST Cu capacitor and inductor
• Crossover components individually pressure-mated
to Panzerholz
• Point-to-point wiring; no Printed Circuit Boards
throughout
• Advanced microvibration control throughout State-of-
the-art Computerized Numerical Control
machining and assembly to the tightest tolerances
achievable today
Design
The laser-precise 10-layer italian piano lacquer finish
requires special know-how and dedication to perfect.
Attractive in the modern domestic interior, this
surprisingly weighty loudspeaker features an ultra-thin
stand which hides the internal signal wires. Thus, a
sleek modernity and clean domestic look is maintained,
while a huge, high performance, enveloping
sound field is created, emanating from sculpturesque
objects of friendly proportions.
Chiara is a very different loudspeaker; one which
projects natural, unforced musical emotion in a most
compelling way.
Technical Specifications
Bandwidth 40Hz – 30kHz ±3dB
Sensitivity 87dB@2.83V
Impedance 4 Ohm
Crossover Point 3100Hz
Recommended Power 150 Watts
Connections Single-wired
Height 1160mm
Width 295mm
Depth 470mm
Weight 34kg ea.
KOMPROMISSLØST!
Priser fra Kr. 165.000,-.
Ta kontakt på:
jep@online.no
90 55 10 11
Features
to Panzerholz
throughout
achievable today
Design
compelling way.
Impedance 4 Ohm
Height 1160mm
Width 295mm
Depth 470mm
Weight 34kg ea.
KOMPROMISSLØST!
Ta kontakt på:
jep@online.no
90 55 10 11
52.5 KB Visninger: 493
32.4 KB Visninger: 471
20.9 KB Visninger: 551
42.5 KB Visninger: 559
