Resultater 1 til 1 av 1
Abonnér på denne artikkelen
  1. På lager NÅ: ADL ( Furutech ) - A 1 bærbar hodetelefonforsterker / DAC
    0 Kommentarer Av pmaudio - 08.02.2015 16:25
    Endelig har vi ADL A1 på lager - sånn at vi også kan levere et sånt produkt også til de som f. eks. har Samsung / Galaxy / Sony mm...
    Med ADL X1 som vi har hatt en del tid er beregnet på iPhone, iPad, iPad så er utvalget nå ganske komplett
    Navn:      1548_ADL_A1-2-Chip[1]_edited-1.jpg
Visninger: 829
Størrelse: 72.8 KbNavn:      1547_ADL_A1-1-Chip[1]_edited-1.jpg
Visninger: 801
Størrelse: 69.7 Kb
    Spesifik info:
    www.pmaudio.no
    ADL A1 | Headphone Amplifiers | Products | ADL
    High-performance CIRRUS LOGIC CS4392K 24bit/192kHz DAC chip (accepts PCM data and DSD audio data )
    Controller supports ASIO and Asynchronous mode
    VIA VT1736 32bit/192kHz USB chip ,USB 2.0 High Speed compliant accepts DSD 2.8M or 5.6M signal & 44.1 /48 /88.2 /96 /176.4 /192 kHz sampling rates supported
    TEXAS INSTRUMENTS TPA6130A2 Headphone Amplifier chip -TPA6130A2 high fidelity Stereo Headphone Amplifier with an SNR of 98 dB
    OP AMP: TI- LME49726 High Current, Low Distortion, Rail-to-Rail Output Audio Operational Amplifier
    Max Headphone Output Levels (at 1%THD 1KHz) : 70mW(12 ohm), 80mW(16 ohm), 65mW(32 ohm), 38mW(56 ohm), 9mW(300 ohm)
    Charge Time: approximately 7 hours approx. (DC 5V, 0.5A USB bus power)
    Charge Time: approximately 5~5.5 hours approx.(AC/DC 5V, 1.0-2.0A switching adaptor)
    Music Playback Time: Up to 7.5 hours when fully charged
    Size: 68(W) x 118(D) x 16.5(H)mm
    Weight: 150g approx.
    Kompatibel med:::
    SONY --- SONY --- Xperia Z3 / Xperia Z3 Compact, Xperia Z , Xperia Z1 , Z1 Compact ( Xperia Z1f ) , Xperia A (Xperia ZR) , Xperia Tablet Z , Xperia V
    SAMSUNG --- GALAXY Note3 , GALAXY Note II , GALAXY S4 , GALAXY S3 , GALAXY S5 , GALAXY S3 mini , GALAXY S5 mini , (not supported - GALAXY S3 mini & S4 mini)
    HTC (Android 4.2) --- J butterfly , J One.butterfly , New One , HTC One (M7)
    HTC (Android 4.3) --- HTC One (M , HTC One X
    Note* HTC One (M7) running v4.3,v4.4.2 not supported
    HTC (Android kitkat 4.4.X) --- HTC One M8
    SInFocus --- IN810
    Ta kontakt for pris: pmaudio@online.no
    Siste redigert av pmaudio; 08.02.2015 kl. 17:17.
  2. Antall kommentarer 0
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
