the Aiwon - Ny top of the line PU fra Acoustical Systems
Etter suksessen med the Archon kommer nå Acoustical Systems med en High End PU i det absolutte toppsjiktet - Aiwon.
Dette er en low output MC.
Pris: 68.800,-
It is with quite a proud feeling of satisfaction and excitement that we present the aiwon©
(ancient greek "the eternal principle of play").
This is our statement regarding low output moving coil phono cartridge design.
It shares the same general architecture with it's smaller brother - the archon©.
It however displays and incorporates a bundle of different improvements in most vital parts - some easy to spot, some very subtle and hidden - in micro design, material composition, individual fine-tuning and - ultimately ... - sonic performance.
The aiwon© is the best example for what improvement is still possible in phono analog front-end sonic performance.
Possible only if all parameters are carefully fine-tuned.
Fine-tuned to thus create much more than the mere sum of the parts.
The aiwon© is "old school" at its very finest.
A sonic performance second to none, - featuring a live-likeness, dynamic contrast, emotion expression and "you are there" character one has to hear to realize what was missing so far - missing in even the very best set-ups.
The aiwon© is carefully handcrafted in Bavaria.
Each aiwon© is handcrafted and carefully fine-tuned to ultimate performance by one person only.
All the perfromance of your analog set-up starts here - in the groove - with the cartridge.
Give the aiwon© a listen in your personal set-up - it will enrich your listening pleasure and musical enjoyment beyond your expectations.
The aiwon© will show you what your audio system is really capable of.
* 0.28 mV output
* high purity 5N silver coils
* ultra-rigid special dampened titanium "Timet 1100" corpus *
* static compliance 16-18 mm/N (18°C to 30°C) * 17 mN recommended tracking force *
* channel balance better 0.35 dB / at 1 kHz * channel separation better 32 dB *
* frequency response 15 Hz to 32 kHz +/- 2 dB * Q4 Shibata EVO stylus *
* internal resistance 4 Ohms * load resistance 100 Ohms *
* cantilever C37-coated tempered aluminum *
* cartridge weight only 11.5 grams *
tom@endpointaudio.no
47832922
svartkeiko
9395 KALDFARNES
Ser at AS klarer å holde vekta på denne på bare 11,5 g.Ser også at Aiwon har bare 0,28 mV i output mot min Archon 0,5.
Anbefalt nåltrykk er også noe mindre.Hvordan spiller denne i forhold til Archon.Jeg opplever at Archon spiller bedre og bedre.Denne er tydeligvis ikke innspilt ennå.
Jeg er så fornøyd med Archon at jeg kan ikke tenke meg annen pickup.
Men jeg vet jo hva jeg skal prøve ved neste pickup kjøp.
Mvh Kenneth
Endpoint Audio
Tønsberg
Flott å høre at du er fornøyd Kenneth! Det er en særdeles bra pickup, og jeg er spent selv på hva mer denne nye kan gi i forhold.
tom e.
Endpoint Audio
Endpoint Audio sine annonser
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
