Resultater 1 til 1 av 1
Nyhet: METRUM AURIX
Abonnér på denne artikkelen
  1. METRUM AURIX
    0 Kommentarer Av Bebophifi12 - 11.01.2014 17:42
    Hodetelefonforsterker fra Metrum, produsent av analogt lydende NOS dac`er. Oppbygd i ren klasse A, her er info fra produsenten:
    During development it proved impossible not to make concessions if the designer would have utilized one of the already established techniques. Therefore this particular route was abandoned and a design was created where voltage gain is achieved via a so-called step-up transformer, instead of transistors or tubes. Only two FET transistors are utilized to convert the signal from the step-up transformer into power, which plays into the strength of these semiconductors.
    The Aurix is a 100% class A amplifier with a very high signal-to-noise ratio and almost no distortion. Because feedback has not been implemented in the design the Aurix has no degradation of the incoming signal in terms of dynamics and imaging.
    In order to ensure the Aurix is flexible and applicable for most headphones it has two gain factors so that both low and high impedance headphones can be utilized. Aside from that the Aurix is equipped with two controllable analogue inputs that, in case no headphone is connected, can loop the signal back to your set. This allows the Aurix to be permanently installed in your hifi-set without you ever having to switch the cables around.
    Prisen er satt til Kr. 11.900,-. Mer info samt et godt tilbud finnes på www.bebophifi.com
    Vedlagte bilder
  2. Antall kommentarer 0
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
