Echole High End kabler servert fra Endpoint Audio
  • Vi har alle signaturmodellene inne slik at du som er interessert kan få testet disse gjennom hele systemet ditt.
    More than a dozen ‘Best of Show’ awards in international shows have been awarded in 2011, 2012 and 2013 to systems equipped with a full loom of Echole Signature interconnects, speaker cables and powercords.
    Les mer om Echole og se prisene her:
    Echole manufactures 4 reference models: Passion, Obsession, Obsession Signature and Omnia. Echole is the first (and indeed the only) cable manufacturer to combine Silver, Gold and Palladium following an intensive five year program of research and development.
    All Echole models are specifically designed to meet the uncompromising demands of dedicated high-end systems. Omnia is the flagship of Echole Cables, meticulously designed and painstakingly hand-crafted to achieve a rare life-like performance regardless of any audiophile criterion. Since 2008, Echole has been awarded as the Best Sound of Show in C.E.S., Munich, and Rocky Mountains Audio Fest by the most reputable press . Recently, Echole Signature synergy is evaluated by Robert Harley of The Absolute Sound Magazine and the performance of Echole Cables together with Absolare electronics has been described as ‘world-class’.
    The opinion leaders in 15 countries agree with this description. All these feedbacks are just few examples within our critically acclaimed global recognition. Echole, the ancient form of Ecole (School), is crafted according to the principles of naturalness and neutrality – the ultimate reference in the realm of ultra highend audio cables.
    Echole Cables are designed with the mission of attaining the absolute best result in every aspect of sound reproduction. Echole Cables are hand-made and tuned by true artisans. The final synergy provides a direct connection to the music borne of greater musical connection. Our clients agree, the reviewers agree. When a full loom of Echole cables were in use, Best Sound was awarded more than 2 dozen times in the international high-end audio shows.
    This performance is a direct consequence of Echole’s design philosophy. Echole cables define naturalness. Echole Cables are effortlessly dynamic , tonally truthful and amazingly organic while remaining totally transparent and open to the source. It is indeed very rare to hear all these often mutually exclusive properties in one cable. Echole borders on sonic alchemy – and in fact, Echole Cables are constructed on cost-no-object conductors made of Silver Gold and Palladium. With every Echole Cable, the music lover is acquiring a significant quantity of precious alloys. When the huge costs of alloys, composites and workmanship are considered, Echole Cables should perhaps be perceived as a component manufacturer.
    Among Echole Cables exclusive features, the most notable are its specialty of signal path and resonance characteristics. The specialty of the signal path is exemplified in the combination of three precious metals: Silver, Gold and Palladium. The resonance characteristics are embodied in the organic composites manually applied to the meticulously handbraided wires.Cost-No-Object, custom-designed alloy from extremely high purity Silver, Gold and Palladium.
    Omnia
    [HR][/HR]​
    The Omnia line of Echole is the most expensively built cable in the market today. Introduced in 2013, the idea is the massive usage of the most precious Silver Gold Palladium alloy derived through a research and development program of 3 years. The final result is reflected as the most organic and life-like, defining naturalness and musical involvement in high-end audio. All audiophile parameters evolve significantly together with a musical involvement that all of our clients state as a paradigm shift. Several opinion leaders in the globe have already stated the Omnia line as their current reference.
    Signal (Per channel) : Several Runs of Teflon-insulated, Solid-Core OMNIAgrade SilverGoldPalladium, hand-braided and fully symmetrical. Termination: Palladium-polished Silver Oyaide terminations.
    Powercord : Several Runs of Teflon insulated Solid-Core OMNIA-grade SilverGoldPalladium and several runs of HPDE-insulated, stranded, 8N purity copper. Termination: Palladium-polished Silver Oyaide terminations.
    Omnia Priser:
    Omnia Interconncet RCA 1 meter: 144.600,-
    Omnia Høyttalerkabel 1 meter: 180.000,-
    Omnia Powercord 1 meter: 114.500,-
    Obsession Signature
    [HR][/HR]​
    The Signature line of Echole is one of the most expensively built cables in the market today. Introduced in 2010, the Signature line is the reference of hundreds of music lovers in the world. More than a dozen ‘Best of Show’ awards in international shows have been awarded in 2011, 2012 and 2013 to systems equipped with a full loom of Echole Signature interconnects, speaker cables and powercords. Due to the heavy usage of the SIGNATURE-grade SilverGoldPalladium, the burn-in process is longer than the Passion and the Obsession models. But once settled, the Signature line is perceived as a component rather than a cable.
    ‘Everything was there- the guttural lows, the pinched but mesmerizing highs, the occasional edge that crept into the longtime smoker’s instrument—in short, the truth of Sarah Vaughan’s voice and the full measure of her interpretive genius. The sound was warm, clear, fully controlled from top to bottom, and rich without ever becoming overly euphonic.’
    CES 2013, Jason Victor Serinus – Stereophile
    ‘Best Sound of the Show’ – CES 2013 – Robert Harley – The Absolute Sound
    ‘Best Sound of the Show’ – Munich High-End 2013 – Robert Harley – The Absolute Sound
    Signal (Per channel) : Teflon-insulated, Solid-Core SIGNATUREgrade SilverGoldPalladium, hand-braided and fully symmetrical. Termination:palladium-polished Silver Oyaide terminations.
    Powercord : Several Runs of Teflon insulated Solid-Core SIGNATURE-grade SilverGoldPalladium and several runs of HPDE-insulated, stranded, 8N purity copper. Termination: Palladium-polished Silver Oyaide terminations.
    Obsession Signature Priser (1 meter)
    Obsession Signature Phono Interconnect – RCA: 27.500,-
    Obsession Signature Phono Interconnect – XLR: 34.500,-
    Obsession Signature Digital Interconnect – RCA: 34.500,-
    Obsession Signature Digital Interconnect – XLR: 37.500,-
    Obsession Signature Interconnect – RCA: 57.500,-
    Obsession Signature Interconnect – XLR: 62.500,-
    Obsession Signature Speaker Cable(2m): 79.500,-
    Obsession Signature Powercord (2m): 49.500,-
    Obsession
    [HR][/HR]​
    Introduced is 2008, Echole Obsession is known as the pioneer cable in the market where Silver Gold and Palladium alloys are used in a solid-core topology. As soon as the Obsession line is introduced, Echole has become a reference by many music lovers. In 2008 RMAF, 2009 CES, MUNICH and RMAF and 2010 CES, the Obsession line has been awarded ‘Best of Show’ by several reputable press. For example, Jason Victor Serinus from Stereophile defines the Obsession performance in RMAF 2009 as follows:
    ‘ The system – wired with Superb Echole cabling has a beautiful, extremely open sound. Not only did it lack even a hint of hardness or grain, it also rendered orchestral cymbals and triangles better than any other system I've heard in the past few years. The presentation was extremely fast and effortless, the sound beautiful to the extreme.’
    Powercord : Several Runs of Teflon insulated Solid-Core OBSESSION-grade SilverGoldPalladium and several runs of HPDE-insulated, stranded, 8N purity copper. Termination: Palladium-polished Silver Oyaide terminations.
    Obsession Priser (1 meter)
    Obsession Digital Interconnect – RCA: 19.000,-
    Obsession Digital Interconnect – XLR: 21.000,-
    Obsession Interconnect – RCA: 31.000,-
    Obsession Interconnect – XLR: 35.000,-
    Obsession Speaker Cable (2m): 49.500,-
    Obsession Power Cable (2m): 28.000,-
    Passion
    [HR][/HR]​
    Introduced in 2013, Echole Passion is the entry level model of Echole Cables. Although being ‘entry-level’, the performance is already perceived to be quite independent of the price range & competition. The ultra-high 8N Purity copper is extruded under extremely strict conditions in the Echole facilities. The proprietory Silver Gold Palladium alloy is plated and triple polished on the surface of the Echole-Specific solid core copper structure. The alloy (Silver Gold Palladium) being plated and hand-polished to precision is known to be unique in the boutique high-end audio cable market. In simpler terms, Echole Cables - being the pioneer of Silver Gold and Palladium alloy - is also a pioneer on plating her unique copper structure with an alloy in the new Passion model. The Echole sonic characteristics are precisely presented in the new Passion model.
    Signal (Per channel) : Solid-Core 8n Purity copper, plated with Echole-exclusive SilverGoldPalladium alloy, hand-braided and fully-symmetrical. Termination: Palladium-polished Silver Oyaide terminations.
    Powercord : Several Runs of Teflon insulated Solid-Core PASSION-grade SilverGoldPalladium and several runs of HPDE-insulated, stranded, 8N purity copper. Termination: Palladium-polished Silver Oyaide terminations.
    Priser kommer.
    hvalross
    Må man betale noe for å få testet disse kablene -depositum eller lign. Erling.
    Endpoint Audio
    Tønsberg
    Ikke hvis jeg blir med kablene. Skal de leveres og testes så blir det et depositum.
    hvalross
    Hvor mye i Depositum . Prosent av kabelprisen eller hva. Erling.
Endpoint Audio
Endpoint Audio sine annonser
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
