TW-acustic lanserer jubileumsmodell - Raven Anniversary
Platespilleren Raven Anniversary markerer TW-acustic sitt 10 års jubileum nå i mars og vil for første gang bli vist frem under High-End messen i München i mai.
Plinten er basert på den til Raven AC, mens tallerkenen er lik den til toppmodellen Raven Black Night. Anniversary-modellen er tilgodesett med et nytt armbrett som strekker seg langs hele den høyre siden av plinten. Alle tonearmer på markedet er støttet og armbrettet har innebygget justering fra 210-310 mm i trinn på 1 mm.
Her er TW-acustic's egen pressemelding:
For ten years now TW Acustic has been making a lasting impression on the turntable market. With our first model – the original Raven – perfect build quality became the standard. Not only that, back then we broke new ground and were the first manufacturer to use a custom-developed synthetic compound based on Delrin. Due to its perfect damping properties, it is almost impossible nowadays to think of a better choice of material than this for modern turntable construction. Also, the use of high-torque motors and sophisticated controllers allowed us to set a new benchmark. Thanks to our developments, music-lovers worldwide are able to indulge their audiophile passions with full satisfaction, and to enjoy their fascination with turntables on an impressive level.
To celebrate TW Acustic’s tenth birthday in March 2013 we present the "Raven AC Anniversary". The Anniversary represents a new statement in turntable manufacture. It is based on the Raven AC chassis, machined from our well-known proprietary custom compound with a screwed-in stainless-steel plate. The Anniversary’s platter is a composite construction consisting of 40mm thick copper fixed to a 20mm thick slice of our proprietary compound. Consequently, the platter is basically equal to that of the Black Night.
Our anniversary model has a very solid armboard machined from 30mm thick aluminium. We can provide the relevant adaptors for every tonearm. To achieve the correct mounting distance, the position of the adaptor for your particular tonearm can be adjusted steplessly in the slot in 1mm increments. To facilitate this we have etched a scale on the armboard showing 210–310mm. Should you wish to install more tonearms, extra swivel bases can be installed as before with the original Raven AC. From an acoustic point of view, the Anniversary offers the same advantages as the Raven AC, but thanks to the modifications keeps a firm eye on its bigger brother the Raven Black Night. Similar to the Black Night, the Anniversary lets the music flow, yet remains composed and pairs dynamics with incomparable transparency.
It is rare in this class to experience such resolution and dynamics in music. With the Raven AC Anniversary we bring you a big step closer to the ideal of real high fidelity musical reproduction.
Produktside: Raven Anniversary
Gjallarhorn Audio
Gjallarhorn Audio sine annonser
Besøk oss på Oslo HiFi Show nå i helgen
Vi har intet mindre enn 6 Norgeslanseringer under Oslo HiFi Show nå i helgen. Du finner oss på rom 106 og 108 i første etasje. Under kan du se hvilke produkter det er Norgespremiere på. Velkommen...
Gjallarhorn lanserer franske B.audio i Norge
  • 5
B.audio er et forholdsvis nystartet firma, men de har i løpet av kort tid blitt anerkjent for sitt gode design og høye lydkvalitet. Firmaet ble grunnlagt i 2016 av brødrene Cédric og Sébastien...
Sveitsiske Stenheim endelig i Norge
  • 10
Varemerket Stenheim ble etablert i 2010 av fem elektronikkingeniører som tidligere hadde jobbet i det sveitsiske high-end firmaet Goldmund. Deres første høyttaler, Alumine, ble lansert i 2011...
Gjallarhorn showroom holder stengt i romjulen
  • 6
Vi lar julefreden senke seg og holder vårt showroom stengt i romjulen. Men vår nettbutikk vil være betjent og det vil fremdeles være mulig å hente varer på vår adresse ved kjøp eller hjemlån i...
Juletilbud på Harbeth (-25%)
Det blir juletilbud på Harbeth ut desember for å få ned vår lagerbeholdning. Alt av modeller, bortsett fra toppmodellen, er på lager i de fleste finisher. Merk at tilbudet om 25% rabatt på...
Juletilbud på SPEC (-25%)
Vi kjører juletilbud på SPEC i hele desember ved å tilby 25% rabatt på alle produktene som befinner seg på lager. SPEC sine integrerte forsterkere er unike klasse D forsterkere med lav effekt...
