Atma-Sphere Novacron er tilbake.
Atma-Sphere Novacron MKIII.1
Disse mono blokkene var første gang produsert i 1991. Det var den første usa produserte forsterkeren som brukte de russiske 6C33C rørene. Nå er den tilbake i en ny og forbedret versjon (MK III.1). Den er nå like driftsikker som resten av Atma-Sphere serien. Den har det velkjente Atma-Sphere lyd signaturen og det klassiske Atma-Sphere designet. En kjempe spennende OTL forsterker(Output TransformerLess)!
Loddefjord HiFi. Atma-Sphere Novacron
Atma-Sphere music systems, inc.
http://www.facebook.com/LoddefjordHiFi
kr 125.000,-
Referanse kunder søkes til Novacron, ta kontakt for referanse kunde pris.
Forhandlere søkes for Atma-Sphere i Norge.
ta kontakt på: Info(at)loddefjordhifi.com eller på PM her på sentralen.
Balanced Differential Design® Class-A operation
Patented Circlotronic® direct-coupled (OTL) output stage
Dual-mono chassis construction
Automatic bias - no adjustment needed
Built in VU meter for tube and output monitoring
Easily monostrapped for greatly increased power
Uses only one gain stage for supreme clarity of sound
Proprietary precision components used throughout
Low-noise "star" grounding topology
Fully hand-wired point-to-point electronics - no circuit boards!
Stable with all input and load conditions
Exclusively uses Octal-Triode based vacuum tubes
Three-year general coverage warranty, one year warranty on output tubes
Output power
60 watts per channel into 8 Ω load
Impedance
Input Impedance: 100 KΩ single-ended, 200 KΩ balanced
Output Impedance: ~2 Ω
Input
3 V sensitivity
RCA and XLR true balanced input
Tube complement
4 x 6C33C power triode
2 x 12AT7 driver tube
2 x 12AU7 driver tube
Gain
23dB ( for 8 Ω )
Power Bandwidth
2Hz-75KHz within ½ dB
Frequency response
( 1 watt, open loop ) 20 Hz squarewave Tilt; unmeasureable
1Hz-200KHz within ½ dB (-3dB @ 1 MHz)
Distortion
Phase shift less than 1° @ 20KHz
Output section risetime
600 V/µs
Power supply storage
600 Joules/chassis
Power consumption
400 watts
Kjetil Melvik
Loddefjord HiFi
Kjetil_M
Kjetil_M sine annonser
The UltraViolet preamp fra Atma-Sphere. Loddefjord HiFi
  • 4
Atma-Sphere har nå kommet med en ny spennende forforsterker. Denne er en god del billigere en de andre Atma-Sphere forforsterkerene. Jeg har dessverre ikke hørt denne enda, men i følge ryktene er...
Loddefjord HiFi: Da er det kommet en ny og forbedret utgave av Zu Omen Def.
  • 1
Zu Omen Def Mk.II Height: 47” [119.5cm] (without footers or optional plinth) Footprint: 12 x 12” [30.5 x 30.5cm] (without optional plinth) Weight: 85 pounds [39kg] each (standard)...
Loddefjord HiFi er blitt forhandler av Peachtree Audio
  • 3
Loddefjord HiFi er blitt forhandler for Peachtree Audio sine fantastiske produkter. Disse forsterkerne låter helt magisk på Zu Audio høyttalere. De blir brukt av Zu Audio på messer sammen med...
Kampanje på Zu Soul Supreme og Zu Druid MkV ved bestilling i November 2013.
  • 1
Loddefjord HiFi: Kampanje på Zu Soul Supreme og Zu Druid MkV! Loddefjord Hifi er den eneste av Zu Audio's forhandlere som fått mulighet til å tilby sine kunder en super deal! Denne kampanjen er...
Demo/utlån av Zu Audio Kabler er nå tilgjengelig. Demo Høyttalere er på vei.
Da har vi fått inn demo sett av Zu Audio kabler. Kabler kan lånes mot depositum. Priser på Zu Audio produktene finner du her Loddefjord HiFi. Zu Audio Priser. I forbindelse med at vi endelig...
Loddefjord HiFi nå med nytt agentur. Zu Audio endelig i Norge igjen!
  • 22
Det er med stor entusiasme og glede at jeg kan meddele at Loddefjord HiFi har fått importørstatus for Zu Audio i Norge. Dette er noe jeg har jobbet med en god stund, og er foreløpig et...
