XP
- Ble medlem
- 04.01.2004
- Innlegg
- 12
- Antall liker
- 0
I en test av et high-performance audiosystem i Positive Feedback, Issue 26/2006, mente skribenten Mike Lavigne at GRAND PRIX AUDIO Monaco Amp Stands forbedret ytelsen til oppsettet betraktelig.
Produsenten - GRAND PRIX AUDIO - påberoper seg å ha markedets mest effektive resonans- og vibrasjonsdempende isolasjonssystemer for high-end audio produkter.
Her er hva Mark Lavigne skrev etter å ha installert GRAND PRIX AUDIO Monaco i sitt system:
"I then tried the Grand Prix Audio amp stands for my main amplifiers (which at that time were the Tenor 300-watt monoblocks). This change had a huge effect again on bass linearity and coherence up and down the frequency range. There seemed to be no limit on the speaker's sensitivity to changes.
Is this a good thing? At that time I wasn't sure. Later on I had the same experience with a second set of Opus speaker cables. The speaker seems to keep on revealing more musical information as you work at improving the associated components."
Interesserte kan finne ytterligere informasjon om GRAND PRIX AUDIO Isolation Systems her:
http://www.highend.no/grandprixaudio.html
Testen fra positive Feedback kan studeres i sin helhet her:
http://www.positive-feedback.com/Issue26/lavigne_vr9.htm
Med vennlig hilsen
HighEnd
www.highend.no
Nordic Distributor of
MONTANA Loudspeakers
PBN OLYMPIA Solid State Amplifiers
Med vennlig hilsen
HighEnd
www.highend.no
