WLM Diva Monitor
Driver / 2-way-CoAx principle
SUPER-TWEETER
10" / 254 mm Paper medium/low Driver
Impedance
8 Ohm
Frequency range
32 Hz – 25 kHz *(part-active with PASSIVE CONTROL)
Sensitivity
97 dB – 1m/1W
Recommended Amp Power
5 to 250 Watt
Wiring Method
Single-Wiring WBT
Dimension
470 mm Height
265 mm Width
330 mm Depth
Weight per Unit
14 Kg
http://www.wlm-loudspeakers.com/indexengl.html
Hilsen
Nordic Sound Design
Base Technology
Ketil Hansen
www.base-technology.no
