http://www.youtube.com/watch?v=_toFscUSG4E
På lager og hos forhandlere, JohnBlue Jb4.
http://www.moiz.no/produkter/johnblu...nblue-jb4.html
Features:
JB4 Mk 2 is Johnblue Audio's top of the line Bookshelf full range speakers. Its enclosure is crafted using 24mm thick high pressured bonded MDF. Thanks to its proprietary internal honeycomb structure, NO fibre is needed internally for damping. This allows for an extremely transparent delivery. Innovative enclosure design allows the driver to radiate sound from the enclosure edge and give it a horn effect. Musical and clean, with a tight punchy bottom end, JB4 Mk 2 have an uncanny ability to “disappear” and easily rivals the LS3/5A.
Like the Flagship JB8, Each pair of JB4 Mk2 is fully laminated with SOLID cherry wood veneer and hand buffed to a achieved a low sheen subtle shine.
Specifications:
Wiring: ALL internal wiring are done with PURE SOLID CORE COPPER.
Driver:
4 inch full range driver with special resin cast waveguide, antifungal treated paper cone, Pioneered and developed by JohnBlue.
Efficiency: 89 dB / W / m
Impedance: 6 Ohm
Max power:30 w
Dimensions H x W x D: 305 x 200 x 270 mm
Weight: 9.5 kg
butikk/forhandler pris: 6000 (veiledende pris: 7000)
