Miles
APRIL TILBUD WLM
Vi har april tilbud på WLM LaScala Monitor og WLM LaScala !
WLM LaScala nå kr : 23 990
WLM LaScala monitor nå kr : 19 900
Nordic Sound Design
www.nordic-sound.com
Technical Specifications
Drivers 2.5" Paper Cone Tweeter
8" Paper Cone Mid/Bass
Impedance 8 Ohm
Frequency Range 40 Hz - 25 kHz
Efficiency 91 dB - 1m/1W
Recommended Amplification 10 to 200 Watts
Connection 5-way binding posts
Dimensions (mm) 20" high x 10" wide x 10.75" deep
Weight 27lbs./each
Impedance 8 Ohm
Frequency Range 30 Hz - 25 kHz
Efficiency 93 dB - 1m/1W
Recommended Amplification 7 to 200 Watts
Dimensions 41" high x 10" wide x 10.75" deep
Weight 58lbs./each
Nordic Sound Design
Impedance 8 Ohm
Weight 27lbs./each
Impedance 8 Ohm
Weight 58lbs./each
